Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum
Register
BFD Forum
two subs
Discuss two subs in the Subwoofer Equalization | Calibration forum; two subs Gonna connect my two subs to the BFD. Wondered whether it was best to split the signal 'before' the BFD ...
Old 05-21-06, 09:07 PM   #1 (Link)
Alias: bob
User: #384
bobgenie is offline
two subs
Gonna connect my two subs to the BFD. Wondered whether it was best to split the signal 'before' the BFD and use two channels or split 'after' using just the one channel?
Cheers
Old 05-21-06, 09:43 PM   #2 (Link)
Loc: Lower Alabama
Re: two subs
Hey bob.... what is the location of your subs? Co-located? Placed symmetrically in the room? etc.
Old 05-22-06, 05:19 AM   #3 (Link)
Alias: bob
User: #384
bobgenie is offline
Re: two subs
The subs are placed in the back corners of the room. Would it be best to use both channels and split the signal before the BFD?
Cheers.
Old 05-22-06, 10:24 AM   #4 (Link)
Loc: Lower Alabama
Re: two subs
I'd say if the room is symmetrical and the subs are placed symmetrical then do like I do... Sub pre-out >>> BFD Input (Channel 1 Left) >>> BFD Output split >>> Subs
I had www.bluejeancables.com build me a 1/4" to dual RCA cable that I use from the BFD Output to the two subs.
I then equalize both subs simultaneously with one channel of the BFD.
Old 05-22-06, 12:19 PM   #5 (Link)
Alias: brucek
User: #6
brucek is online now
Re: two subs
Not that I would ever disagree with Sonnie, but
if he split the signal before the BFD, then it would add the extra capability to individually equalize the two subs in case they aren't exactly the same. If they were the same, it would still only require one set of filter inputs in 'couple' mode?
Old 05-22-06, 12:40 PM   #6 (Link)
Loc: Lower Alabama
Re: two subs
Now why didn't you tell me that when I was trying to figure out the best way to do it. Fortunately... mine worked out... AFTER I had already spent the money on the cable.
Old 05-22-06, 03:00 PM   #7 (Link)
Alias: bob
User: #384
bobgenie is offline
Re: two subs
My room is not perfectly symetrical so I'm going to go for the split before the BFD and adjust both channels. This of course will also make it a little bit more difficult for my feeble brain
I am ordering the cables tomorrow
many thanks both!
Old 05-22-06, 05:20 PM   #8 (Link)
Loc: Lower Alabama
Re: two subs
Yeah... it will be a challenge in your situation no doubt. I've not seen too many of those work out too well for some reason. Seems like most have ended up co-locating them after several attempts to equalize separately.
Old 05-22-06, 09:30 PM   #9 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: two subs
As an expert cable builder, I find the prospects of splitting a signal from an RCA connector pretty “iffy.” Most of them barely have enough room in the barrel for a single cable, much less two. The strain relief certainly won’t handle two cables.
Maybe Blue Jeans has a special RCA for this, but I think it makes much more sense to do the spilt-off at the XLR, a short jumper that would connect to the BFD’s second channel. This would be the electrical equivalent of splitting at the RCA. Not to mention, there’s no good reason to have two long cables running to the BFD from the receiver when one will do.
So, you might see if Blue Jeans will make the cable for you with the split at the XLR.
Old 05-22-06, 09:48 PM   #10 (Link)
Loc: Lower Alabama
Re: two subs
They split off the 1/4" connector to two RCA's for me... no problem. I believe they used the Beldon 1505F cables, which are smaller... and they fit nicely.
In his case he'd need to split off his RCA (sub pre-out) to either two 1/4" or two XLR's. If they use one of the large barrell RCA they should be able to get two of the 1505F's in there pretty easy.
John at Apature told me when I ordered some cables from him that he could have built it for me cheaper so you might check with him. Not sure what cable he uses but the ones I got from him look nice and they were super cheap.
Old 01-04-07, 09:01 AM   #11 (Link)
Alias: Moe
User: #4510
Since: Nov 2006
Moez is offline
Re: two subs
Hi Wayne,
Looking for a good subwoofer cable and I'm looking at Tara Labs 2200 SW cable....are there really many differences between the better sw cables that are costing $35 per meter?
Old 01-04-07, 11:25 AM   #12 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: two subs
Moe,
Subwoofers don’t require anything special in the way of cabling. Some people here have used plain-old RG-6 coaxial with screw-on F-to-RCA adapters. Get the cheapest, well-made cable you can find.
Old 01-04-07, 11:31 AM   #13 (Link)
Alias: Moe
User: #4510
Since: Nov 2006
Moez is offline
Re: two subs
thanks for advice Wayne....
Old 10-22-07, 10:53 AM   #14 (Link)
Alias: Brad
User: #12504
Since: Oct 2007
Tiny is offline
Re: two subs
brucek wrote: View Post
This is similar to what I do with my two subs in the back. I split at the pre-out from the receiver, run it through a 1/3 octave equalizer, then into my adcom 5800 then to each sub independently.
Old 10-22-07, 10:57 AM   #15 (Link)
Alias: Brad
User: #12504
Since: Oct 2007
Tiny is offline
Re: two subs
Moe,
i think most people pay way to much for cabling to start with, they are more impressed with stat numbers crunched than if they can actually hear a difference. Both my DIY subs are fed with 14 gauge wire from walmart at about a $0.25 or less and connected with $0.20 banana plugs and sound great. (That might have a lot to do the adcom 5800 powering them)
Old 10-22-07, 03:07 PM   #16 (Link)
Alias: Doug Plumb
Loc: Toronto Ontario
User: #7543
Since: Mar 2007
Doug Plumb is offline
Re: two subs
Experiment with placement of your subs and reverse polarity of one for each test location set.
Use the BFD going into both after you are done finding the best placement - ie the placement that excites the greatest number of modes at your listening area. Find the best placement that gets the greatest number of modes then calm down any that you need to with the EQ.
Doug Plumb
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now
