| BFD Forum Is a Behringer DCX2496 any good for HTDiscuss Is a Behringer DCX2496 any good for HT in the Subwoofer Equalization | Calibration forum; Is a Behringer DCX2496 any good for HT I can get a DCX for a steal is this better than a DSP1124 or a FBQ2496 ?
I have ... |
| | #2 (Link) | ||||
| Re: Is a Behringer DCX2496 any good for HT Quote:
brucek | ||||
| | #4 (Link) | ||||
I believe many don't realize how versatile unit it is. The only thing where it stays behind those two is the minimum width of the filter, Q=10. Not a bad flaw though, one shouldn't use any sharper filters than that anyways. | ||||
| | #6 (Link) | ||||
What are the benefits of the DCX2496 compared to the DEQ2496 compared to the BFD1124. I'm thinking of moving away from the 1124 as described here. I also looked at the DCX2496. I like its low pass filter at a 24 dB per octave slope; I think the DEQ2496 shelf filters are at 12 dB, but I think you can add the GEQ to that. I browsed the DCX manual, and I didn't find good information on the PEQ either. It almost looked like there's only one, but that doesn't quite make sense. For whatever reason, Acrobat didn't want to search nicely today; I couldn't "find" anything in the document, even words that I can see on the screen in front of me (I searched up as well down, and allowed it to "wrap" when I got back to the top of the page. -- Otto | ||||
| | #7 (Link) | |||
| Re: Is a Behringer DCX2496 any good for HT After a quick look at the specs of the DCX2496 it looks like a very interesting piece of gear. I've just downloaded all the user manuals for all the behringer eqs and crossovers, its a stack about 2 inches thick, looks like I've got some reading to do. I haven't bought a new piece of gear for about six months, I'm long overdue for a new toy. Hakka. | |||
| | #8 (Link) | |||
| Re: Is a Behringer DCX2496 any good for HT I've read some of the DCX2496 manual and it keeps mentioning a 'dynamic eq', can someone tell me what this is and how is it different to the parametric eq? I've been planning to go to an active biamp setup for a while now and I'm gonna buy the DCX in the next few weeks. I still need to get some more amps and either mod my speakers or build new ones, so the active setup is not happening anytime soon. In the meantime I might use this as an eq for my mains, there are some nasty bass humps I can't get rid of, how effective would the unit be in this application? Hakka. | |||
| | #9 (Link) | ||||
Implementing it properly would require that we measure the frequency range of interest over a variety of levels, then determing how much gain or cut would be necessary at each level. I've not seen much discussion of this around here, but it would be a fun thing to start working on. -- Otto | ||||
| | #10 (Link) | |||
| Re: Is a Behringer DCX2496 any good for HT I originally was looking to buy one for my P/A system, where I can take my signal feed and send it to this unit. It is buy all means as posted above a bass management system, with extra's. I like extra's, I wish the DSP1124 has a front like the DEQ2496 .But it seems to have a lot of other goodies, but it mentions a PEQ , but nowhere can I find how many channels. Maybe one PEQ per channel I know it takes a left right channel and you can set X_Overs for Bass, Mid and Highs. Then send the three channels to the individual speakers. Which is awsome, but I wouldn't really want to send it back to my highs and mids, as I think you would get to mush noise. | |||
| | #11 (Link) | ||||
Currently I run my whole front-end (LCR) and subwoofer through it.I'd suggest to DL the remote software. That will make you realize how capable this unit really is. It will run even without the unit. http://www.behringer.com/DCX2496/index.cfm?lang=ENG (->software updates) | ||||
| | #12 (Link) | ||||
Thanks. | ||||
| | #13 (Link) | |||
| Re: Is a Behringer DCX2496 any good for HT I have had a DCX2496 for about three months and really like it. I purchased it because it is not only a parametric equalizer, but it also has 6 outputs, is a digital crossover, and can be controlled by the computer with the downloadable software and a cheap serial cable. You can also buy a bluetooth to serial device and not even use a cable to your computer! The DCX2496 will also auto-align multitple subwoofers (using an ECM8000 microphone). I send it a digital 96 kHz signal from my X-Fi Elite soundcard via the spdif output. The X-Fi performs digital volume attentuation and then sends the signal out through both the analog and digital outputs. The analog outputs go directly to my 7 channel amplifier. The digital output goes to the DCX2496 via input A. Like Ilkka said, it has 9 parametric bands for each input and output. For bass management purposes, this gives you a total of 18 bands of parametric equalization which is more than enough. I send input A to output A for my subwoofer with the high pass crossover off and the low pass crossover set to 50 Hz. I also send input A to output B for my HSU MBM-12 mid bass module with a high pass crossover at 50 Hz and a low pass crossover of 121 Hz. The crossover in the X-Fi for my analog output is also 121 Hz. Finally, I send input A to output C for my Buttkicker amplifier using a low pass crossover of 50 Hz. The phase and delay is also adjustable for each output. In addition, the DCX2496 will perform auto-alignment which adjusts the delay of the outputs so that the subwoofer and mid-bass module are aligned. I tested repeatedly and received results within a few inches. The results were very close to the actual distance between the two units. Since my subwoofer is right next to my right front main, it does not need any delay. I had never used a paramentric equalizer and found the DCX2496 very easy to use and setup. Once you have it connected to your computer, you don't even have to touch the unit again (I leave it on all the time). You can store 60 presets internally and on a pcmcia card. You can also store the presets on your computer in case you need to reset the DCX2496. Again, you can easily switch presets using the computer for comparing settings, house curves, etc., crossovers (12-48dB/octave), etc. Here are some links of interest: Behringer DCX2496 webpage Behringer Specifications Remote Software You can download and use to get a feel for the DCX2496 with have the DCX2496 present. Website devoted to DCX2496 Last edited by mojave; 05-21-07 at 04:42 PM. | |||
| | #14 (Link) | ||||
A input = left main (from receiver, pre out) B input = right main (from receiver, pre out) C input = center channel (from receiver, pre out) 1 output = left main (to separate power amp) 2 output = right main (to separate power amp) 3 output = center channel (to receiver, main in) 4-6 outputs = 1-3 subwoofers | ||||
| | #15 (Link) | ||||||
| Re: Is a Behringer DCX2496 any good for HT Ohhh, I love this thread! ![]() Rencently a Hawthorne forum member was kind enough to loan me his DEQ2496 and DCX2496 to see if they'd "fit my bill". I've got a 5.1 HT rig currently using two sub channels. So technically it's a 5.2 I suppose. I've installed the DEQ first and have it running. I didn't want too many buttons in the mix, I figured I'd wait until I was comfortable with the DEQ before I installed the DCX. I've got a few questions so far. Quote:
#1, When you say 7 channel amp, are you refering to a digital receiver, dedicated surround processor, or just an amp with 7 channels? #2 What's the purpose of outputting analog and digital of the same signal going to two different places? Is this so one of the pieces of equipment can pick up the rear channels. #3 Are your XLR cables balanced or unbalanced. (and is unbalanced OK for HT?) #4 Is the soundcards analog outputs seven descrete channels/cables? in addition to optical? Quote:
I such a virgin with equipment like this. ![]() I'm currently only using optical in and out of the unit from a DVD player through the DEQ to the receiver. 2 channel music works fine, sounds great. However, when I put a DVD in, the input LED's are almost pegged and I get ZERO sound?! ![]() ![]() Very interested in the PC integration too. Thanks for the links! ![]() Bob | ||||||
| | #16 (Link) | |||
| Re: Is a Behringer DCX2496 any good for HT It seems like the consensus is that the DCX2496 is better overall for sub use than the FBQ's. This is what I wanted to know. How does it compare to the DEQ2496? Do any of these units have EQ below 20hz? I'm trying to avoid getting a Rane PE-17. | |||
| | #17 (Link) | |||||||||
My soundcard takes all channels and combines them into a digital stereo PCM signal for output via spdif. Because this output is simultaneous with the analog output, I can send it to the DCX2496. This has several benefits: it bypasses the bass management of the soundcard so the bass isn't changed, it sends all frequencies from all channels (subwoofer, LFE, bass in mains, etc) so that I can perform the bass managment that I want, it elimates an analog to digital and digital to analog conversion step, it eliminates problems with an analog signal that isn't attentuated enough by the soundcard. Quote:
I recently submitted a question to Behringer about the 20Hz limit on their equalizers. They said that is as low as it can go due to the hardware. They cannot make a bios revision to provide a lower limit. I'm still not sure if a filter that is set to 20Hz will effect signals below that or not. I need to do some more testing, but haven't had time. | |||||||||
| | #18 (Link) | ||||
| Re: Is a Behringer DCX2496 any good for HT It has. Quote:
| | #19 (Link) | |||
| Re: Is a Behringer DCX2496 any good for HT I thought it probably would. It seems like a filter at 20 Hz would be sufficient for most purposes. I would like to see a few measurements if you have them readily avalable. It might help some not worry as much about having a filter set lower than 20 Hz. Thanks. | |||
| | #20 (Link) | |||
| Re: Is a Behringer DCX2496 any good for HT Duplicating 20Hz filters on the BFD will give you boost down to around 10Hz. With my 4 x 15" IB I seem to get a true boost in output to match a single boost setting of the filter pair. This duplication (or ganging if you prefer) is more than twice as powerful than using a +16dB filter at 20Hz so be very careful with high listening levels. You won't hear anything until your toasted driver cone flops onto the floor! I am using 2 identical filters @ 20Hz +8dB 120/60 BFD filters instead of a single +16dB @ 20 Hz. So I get an 8dB boost at the bottom end. (Thanks to ThomasW of the IB Cult for this clever idea) Be very careful indeed with 20Hz boost filters! Most subs probably can't handle much. I increased my duplicate filters 1dB at a time testing continuously for cone excursion right down to 6Hz with REW. Just to ensure I wouldn't blow my drivers apart. Be warned: It is not just a matter of whacking in a double 20Hz boost filter then trying WOTW at reference level! I have just been trying sinewaves at fairly high SPLs down to 6Hz to see if there was any real benefit. I can assure you that such low frequencies are completely silent even if you can feel the pressure in the room as you read 100dB(C) on your Galaxy 140 SPL meter. These very low frequencies also made my hair vibrate as I approached the manifold. It felt like pulsing static. ![]() | |||
