FBQ2496 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
FBQ2496
Discuss FBQ2496 in the Subwoofer Equalization | Calibration forum; FBQ2496 Hi, Finally managed to get all the gear together, new cables connected and give it all a shot. Turned it ...
Old 06-02-06, 08:30 AM   #1 (Link)
Alias: bob
User: #384
  bobgenie is offline
FBQ2496
Hi,
Finally managed to get all the gear together, new cables connected and give it all a shot. Turned it all on and blow me the 2496 is totally different to the one in the guide actually I'm sure it's similar but will need to get my head down i suppose.
First couple of questions though. In bypass mode I had to turn my amp up to ridiculous amounts to get a sign of LED. Should I then keep the amp on high and turn down the subs to see this or is it so important?
If I have both lights on (left and right) does this indicated couple mode as i have two subs each connected to left and right and one input to the left.
Wish I'd bought the other model now, sure it would have been easier
Cheers.
Old 06-02-06, 09:50 AM   #2 (Link)
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: FBQ2496
Hey bob,
The BFD should be inline between your receiver or pre-pro and your sub amp. The sub pre-out is adjusted to achieve the proper input level in Bypass mode. Then you set your volume on your sub to level match with your mains.
Couple mode is pressing both engine buttons simultaneously. To make sure they are uncoupled I beleive you would do the same. Then to use each engine independently simply press the left engine button and then the right engine button, turning both on independently. But I'm not 100% sure this is correct on the 2496. I think this is something that is actually pretty well explained in the manual though.
Most everything will be the same on that unit, except you will get more filters per channel.... BUT you lose any extra presets as there is only one preset per channel. Okay... you would have saved a few bucks too. I know... just pile it on.
Old 06-02-06, 01:33 PM   #3 (Link)
Alias: bob
User: #384
  bobgenie is offline
Re: FBQ2496
Thanks Sonnie, I do have it in couple mode but I only get output from which ever input I have connected. I have one cable from my amp and each of the two subs have an individual cable left and right channel. I assumed that couple mode would mean that 1 input should provide the same signal to both channels. This isn't happening and no matter how I configure it won't provide the signal to both outputs. If I plug right output I get right sub working and vice versa for the left. I have couple mode working as both lights are on. Is there something wrong with the unit or am I thinking wrongly here?
Cheers.
Old 06-02-06, 02:32 PM   #4 (Link)
  Sonnie is offline
Re: FBQ2496
Couple mode provides duplicate filtering for each channel, but you still have to have an input (it will not activate the outputs... the engines don't activate the output, they activate the filtering). You will need to split your sub pre-out to both inputs or do as I do and split your the output to two subs.
EDITED!
Old 06-02-06, 03:02 PM   #5 (Link)
Alias: brucek
User: #6
  brucek is offline
Re: FBQ2496
Couple mode is only a convenience that allows entering the filters once and they are copied to both channels. Other than that the channels are completely independant as sonnie says.
Splitting the input signal to the BFD allows future flexibility of independant filtering of each channel.
Old 06-02-06, 05:05 PM   #6 (Link)
Alias: bob
User: #384
  bobgenie is offline
Re: FBQ2496
got it. So I'll have to get a splitter in before the BFD. Better get on the phone again
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
