Finally going to attempt to use bfd,help ! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Finally going to attempt to use bfd,help ! in the Subwoofer Equalization | Calibration forum; Finally going to attempt to use bfd,help ! I finally finished my basement home theater and am ready to tackle this bfd that i have had for two ...
Old 06-30-07, 10:26 PM   #1 (Link)
New Member
Alias: cardoc
Loc: I ain't tellin ya!
User: #960
Since: Jun 2006
  cardoc4551 is offline
I finally finished my basement home theater and am ready to tackle this bfd that i have had for two years connected in my system but have not used the eq yet!Just a heads up on the room size,11.5 wide x 22ft long x 7ft high.Now heres where its gets interesting,i have 2 def tech main speakers with 15 inch subs on the front wall and in the back corners i have 2 (one in each corner) svs pb12+2.Now did i tell you i like bass! But i also like it to sound good also.Well since i am not equiped to use the room eq setup i went the old fashioned way using the older radio shack meter and excel chart.Well the graph that i charted is horrifing to say the least.Help is definatly needed,where do i start here,i would like to use one channel of the bfd for the svs subs and the other for the deftechs,is this possible.Another thing to note here is that the measurements were taken with just the subs on,the amps for the other speakers were turned off.I have also beleive it or not have set the spl level with my other speakers and am about ten db hot with all the subs on together.
Old 07-01-07, 08:12 AM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
  Otto is offline
Re: Finally going to attempt to use bfd,help !
Hey there, cardoc, and welcome to the Shack!
Have you ever used RoomEQWizard? The documents for REW are here. I'd probably start there. Read through it at your leisure, and start getting the parts together. If you are planning to effectively EQ your subs, you will need this tool.
As to using the BFD to EQ your Definitives and your SVS subs, I can say that it is indeed possible. Previously, I too used Definitives (BP2002 w/ 12" sub in each) and a stand-alone sub at the same time, all EQd with one BFD (I later went to two). It will depend on your particular setup and desires, but yes, in general, it can be done.
When I had that set up, I EQd each Definitive on its own BFD channel to maintain the left and right signals to each speaker. I then used another BFD to EQ the sub. I did this because I have a focus on music, and wanted to keep my mains L/R balanced. To achieve this, I was running preamp outs from my preamp to each Definitive. If you run L/R pre outs from your preamp to your Definitives, you will need at least two BFDs.
If you are running sub outs to your Definitives as well as your SVS subs, you can do it with one BFD. I would recommend EQing the whole thing as one, and be done with it. You will get the best response that way.
Either way, I would imagine that you should have no problem getting bass!
-- Otto
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
First attempt at H/T speakers Rzarector DIY Speakers 5 04-04-07 01:54 AM
first manual attempt? PhilB35 REW Forum 23 02-14-07 10:32 AM
Finally Have BFD First Measurement 11B2P REW Forum 19 09-01-06 01:27 PM
Newbie's first attempt B4 and after gtv REW Forum 3 07-06-06 02:42 AM
1st attempt with BFD... your comments? highcurrent REW Forum 8 05-07-06 04:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
