Best way to connect BFD to computer? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Best way to connect BFD to computer? in the Subwoofer Equalization | Calibration forum; Best way to connect BFD to computer? Please help, I am wanting to get something for this weekend and I will have to order it so I ...
Old 06-06-06, 12:48 PM   #1 (Link)
Alias: Greg Cole
Loc: Springfield, MO
User: #765
gacole2000 is offline
Please help, I am wanting to get something for this weekend and I will have to order it so I need suggestions on a low cost interface ASAP. Is there a USB to MIDI cable that most people suggest and use here?
Thanks!
AVR: Yamaha HTR-5890
DVD: Yamaha DV-C6480
BFD 1124P
Mains: Polk RT55
Center: CS300
Sides: RT/FX
Rears: RT25i
Subs: SVS 20-39 PC+ (12.3 ordered)
DIY w/ SVS 12.1 driver
HDTV: Panasonic PT-53WX42 -ISF Calibrated
IC's: IXOS "Gold" & Gamma spkr wire
Power: Panamax MAX 5100
Remote: Pronto Neo
Old 06-06-06, 02:06 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Best way to connect BFD to computer?
A popular interface is the Edirol UM-1X USB/MIDI interface. It appears the Edirol UM-1EX may be its future replacement.
You'll also need a 10-15' MIDI cable to go from the interface to the BFD.
I generally search Froogle for these kinds of things to find the cheapest price, but they are scattered about everywhere.
Old 06-07-06, 12:51 PM   #3 (Link)
Alias: Bob
Loc: Lytham-St-Annes, UK
Malice's Avatar
User: #304
Malice is offline
FWIW, my PC (desktop) has a soundcard with a gameport. This can be used to get a MIDI connection to the BFD, but your PC will need the gameport. This is the cable that does the trick. I have used this solution with no issues at all.
HTH
Bob
| Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant|
Bob - "Malice" was my Quake 2 CTF name
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Mach 5 Audio
