Method to dim DSP1124P LEDs - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Method to dim DSP1124P LEDs in the Subwoofer Equalization | Calibration forum; Method to dim DSP1124P LEDs I just noted in Otto's post on "Rack Ears" a comment about using window tint to dim the front panel ...
Old 06-06-06, 04:50 PM   #1 (Link)
Alias: Chuck
Loc: Marietta, GA
User: #947
Since: Jun 2006
catnip is offline
I just noted in Otto's post on "Rack Ears" a comment about using window tint to dim the front panel LED's. I just finished a new method (new at least to me!) that may interest others. If someone else has already posted this idea, please forgive my redundancy.
If you remove the left rack ear and look behind the front panel, you will see that there is a small clearance between the LEDs and the front panel ... around 1/16 inch or less. This gave me the idea of inserting some dimming material between the LEDs and the front panel.
Now, what could we use for dimming material? Well, after a bit of thought, I recalled that I had some ink jet printer transparency film. Using PowerPoint (most any other graphics tools will likely work) I created four rectangular boxes (1.5 by 9.5 inches) on a single page and filled them with four shades of gray starting with black and moving to a medium gray. I printed the image on transparency film using a Canon i960 printer and trimmed the rectangles to size. They fit perfectly between the front panel and LEDs and you can experiment with the level of dimming you like using one or more strips.
This method takes care of the LEDs to the left of the jog wheel; the ones to the right remain as-is, but they seem less intrusive than the ones on the left.
Hopefully someone will find this idea useful!
Chuck
Old 06-06-06, 08:13 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Method to dim DSP1124P LEDs
Great idea!
What I usually recommend is getting some scrap window tint from a tint shop, either 20% or 8% depending on how much dimming you need. It has an adhesive back, so you can cut to size and stick it on the front panel over the LED’s. The adhesive isn’t fully activated without a special solution, so it will come off easily should the need arise.
Old 06-07-06, 01:27 AM   #3 (Link)
Loc: Lower Alabama
Sonnie is offline
Chuck... that is a pretty neat idea. I suspect you could take several shades of window tint and stick them on the back side.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
