Apply filter - no sound - BFD - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Apply filter - no sound - BFD in the Subwoofer Equalization | Calibration forum; Apply filter - no sound - BFD Sonnie. Bruce et all. Hope things are well.. I have applied my first filter. woo-hoo. I applied a nice easy ...
Old 04-24-06, 03:56 PM   #1 (Link)
Alias: DeafJeff
Loc: Atlanta, GA
User: #139
jeffbridges is offline
Sonnie. Bruce et all. Hope things are well.. I have applied my first filter. woo-hoo. I applied a nice easy -3db cut at 20HZ with a Bandwidth of 5 (still dont understand BW fully, but it doesnt matter for the purposes of this) . Stored it and retested with rat shack meter. 16 hz was slightly lower, but 20hz was inaudible and did not register on meter. I set it all to +1 with a more narrow BW setting, and with the filter applied, same thing, nothing at 20hz. Turn off filter, and back to normal.
I am SO close to getting this all set up, and I know I am doing something stupid and figure you guys might have made same mistake before.
Any ideas? Jeff
Old 04-24-06, 05:06 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Apply filter - no sound - BFD
Hey Jeff and welcome to the Shack!
I think the first thing we need to see is your response graph. Are you using the Microsoft Excel Workbook or Room EQ Wizard?
Your answer will guide us in the direction we need to go.
Sonnie
Old 04-24-06, 06:11 PM   #3 (Link)
Alias: DeafJeff
Loc: Atlanta, GA
User: #139
I tried REW a while back, and didnt have luck, so decided to just use the excel file (latest one) - (the file is named with "25hz" in it because my HSU VTF-3 sub can be adjusted to go down below 20hz, or to plug a port and play louder at 25hz. I tested it at the 25hz setting"
here ya go! jb
File Type: xls Sub Spreadsheet for BFD - jeff final at 25 Hz.xls (35.0 KB, 9 views)
Old 04-24-06, 06:50 PM   #4 (Link)
Alias: brucek
User: #6
brucek is online now
Are you sure that the FILTER MODE for that filter is set to PA and not SI or AU ?
I've never seen such a fault like that before.
The filter is at 20Hz and the problem is at 22Hz. And if you turn that filter off the fault goes away?
If you choose a different filter and / or another program slot, does it still do it?
Old 04-24-06, 07:01 PM   #5 (Link)
Alias: DeafJeff
Loc: Atlanta, GA
User: #139
Yep - I am using "channel 10" (PA Mode) and filter #1. all other filters "under" 10 are set to OF. I will try a different "slot" in the AM (kids are home in bed)
So Filter enabled, nothing at 20HZ, bypass filter and get all of it @ 20.
Old 04-24-06, 07:29 PM   #6 (Link)
Alias: brucek
User: #6
Mmmm, I don't have my manual near, but aren't the last two or three channels (8 to 10) a bit different than the rest - I don't remember.
I think most people use #4 to start because its all set up for PA......
Old 04-24-06, 07:33 PM   #7 (Link)
Loc: Lower Alabama
Sonnie is offline
... that is definitely about the strangest I've seen before. There's definitely a snake in the woodpile.
Like brucek shows... it appears you have a filter at 20hz and I see another at 25hz... but nothing at 22hz. I really wouldn't even see a need for a filter at 20 and 25hz anyway.
OHHHH... whoa nellie... those are not all your settings there. Those are defaults I have set in the Workbook. I need to fix that so we know what's what. My bad... I'm causing the confusion on that part.
But still... something ain't right for sure.
Sonnie
Old 04-24-06, 09:22 PM   #8 (Link)
Alias: DeafJeff
Loc: Atlanta, GA
User: #139
Brucek - I thought I had read that channel 10 was a good choice as it would default back after a power outage? Should I change to 4?
Old 04-24-06, 09:22 PM   #9 (Link)
Alias: DeafJeff
Loc: Atlanta, GA
User: #139
submit hung - delete
Old 04-24-06, 10:12 PM   #10 (Link)
Alias: brucek
User: #6
All the channels retain their settings after a power out.....
Huh?
Old 04-25-06, 03:09 PM   #11 (Link)
Alias: DeafJeff
Loc: Atlanta, GA
User: #139
I think I fixed my problem, but not sure exactly how. I bought the BFD used, so I bet there was some filters set that I needed to clear out. I cleared them all out, and moved my filters to channel 4. I got a response that is much closer to what I expect to see, but am no where close to being "flat." I will open a new thread with before / after and all pertinent info. Thanks everyone, Jeff
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
