DCX2496 vs. DEQ2496 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
DCX2496 vs. DEQ2496
Discuss DCX2496 vs. DEQ2496 in the Subwoofer Equalization | Calibration forum; DCX2496 vs. DEQ2496 I've been reading about both of these and my head is sort of spinning. I've gathered that Illka owns and ...
Old 10-24-07, 10:05 PM   #1 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
DCX2496 vs. DEQ2496
I've been reading about both of these and my head is sort of spinning. I've gathered that Illka owns and likes the DCX model, but I am still wondering what the differences are... or more specifically, is there anything the DCX can do that the DEQ cannot (for subwoofer/bass management)?
Also, still not clear on how the shelf filter works... the whole 6/12 dB thing. Is that just the slope at the cutoff/transition frequency? For example, if you created a high shelf filter at 20 Hz (to boost everything above 20 Hz) would it still have some influence on frequencies below 20 Hz?
I am wondering if you can use static gain to cut all frequencies and then a shelf (or maybe multiple PEQs) to bring frequencies in the normal operating range back up. Is that possible... feasible... sensible? The idea is to find a substitute for a true HPF that you could set to 10 Hz.
Somebody straighten me out here.
Thanks.
Bradley
Old 10-24-07, 10:15 PM   #2 (Link)
Alias: terry
Loc: bathurst nsw australia
User: #1819
terry j is online now
Re: DCX2496 vs. DEQ2496
the dcx is basically an extremely versatile x-over unit, and has some degree of PEQ capability.
The deq has no x-over functions, that is very rich indeed in both GEQ and PEQ.
The deq has a much higher sound quality than the bfds (well, I must be honest I haven't done a side by side but I think it is true) and can do anything the bfd's can do and more.
Think by design none of the behringer gear is designed to do anything below 20 hz, it is pro gear. You may of course get results below 20 as a result of something you do (shelf filter for example).
Old 10-25-07, 08:40 AM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
Shelves are a hinge at the shelf starting frequency.......
Use REW to take a response of your receiver sub and equalizer loop. You will probably find the HPF at 10Hz already exists, free of charge.............
Old 10-25-07, 10:42 AM   #4 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
Good point. I know I shouldn't try too hard to solve a problem that very well may not even exist.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Any reason not to go to DEQ2496? Otto BFD Forum 18 12-14-07 12:49 AM
dcx2496 attenuation SleepingRobot BFD Forum 17 07-31-07 03:05 PM
Is a Behringer DCX2496 any good for HT doreytp BFD Forum 38 06-10-07 03:32 PM
DEQ2496 opinions clubfoot BFD Forum 5 05-06-07 10:25 AM
Greetings from new DEQ2496 owner nathanso Welcome | Member Introduction 5 11-01-06 03:53 PM
Mach 5 Audio
