How important is setting the absolute maximum peak input level? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss How important is setting the absolute maximum peak input level? in the Subwoofer Equalization | Calibration forum; How important is setting the absolute maximum peak input level? According to what I have read, when setting up the BFD it should be at the -10db input and set ...
Old 12-07-07, 02:59 PM   #1 (Link)
Alias: lovingdvd
User: #5942
Since: Jan 2007
  lovingdvd is offline
According to what I have read, when setting up the BFD it should be at the -10db input and set up so that at the maximum listening volume, the output level of the sub from the AVR should be set so that the maximum deepest bass causes the BFD red light to come on for no more than a flicker here and there.
And if I understand correctly, its equally important that the output level from the AVR is not too low, otherwise this introduces distortion.
What I am wondering, however, is just how important it is to really find that maximum peak level. Lets say that I had my AVR set so that at the maximum level the top green LED came on but orange did not or barely flickered (instead taking it up to red). In that scenario would I likely notice ANY difference in sound quality from my sub (assuming the sub gain was then adjusted to compensate for the proper level calibration)?
I ask because I have a bit of an issue where my PS3 Blu Ray output LFE is about 8db stronger than my Toshiba XA2 HD DVD player - not sure why. But none the less I've compensated for this by using a -8db trim on the LFE only when playing the Blu Ray.
However I also needed to drop the output level from the AVR a bit to still keep it from clipping into the red. So things are nearly perfect now with the PS3 but with the XA2 the signal from the AVR is a bit lower.
Normally I wouldn't think this would make a difference. However after making this change the deepest base from the Nine Inch Nails HD DVD sounded a bit distorted/muffled compared to when I had the AVR output set a few clicks higher. And all green LEDs are light and no orange/red so I know I'm not over driving it. Just curious why this may be happening? Could just a two clicks lower on the AVR's subwoofer output level make any noticeable difference?
Thanks!
Old 12-07-07, 03:32 PM   #2 (Link)
Alias: brucek
User: #6
  brucek is offline
Re: How important is setting the absolute maximum peak input level?
No, you would not notice any difference.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Setting BFD input level? tdamocles BFD Forum 3 03-05-07 03:37 PM
Can I control the absolute level with the BFD?? Julien43 BFD Forum 5 02-25-07 07:42 PM
? on Setting the input level on BFD kryolla BFD Forum 5 11-01-06 09:44 PM
Input -level setting "approved DVDs"? Greybeard191 REW Forum 3 09-13-06 11:14 PM
trouble setting up input Tonio REW Forum 6 06-20-06 06:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
