| BFD Forum My first session with my new FBQ2496 - Results inside...Discuss My first session with my new FBQ2496 - Results inside... in the Subwoofer Equalization | Calibration forum; My first session with my new FBQ2496 - Results inside... Well, I received my FBQ2496 today and thought I would take an hour or two to play with it...yeah right. ... |
| | #1 (Link) | |||
| My first session with my new FBQ2496 - Results inside... Well, I received my FBQ2496 today and thought I would take an hour or two to play with it...yeah right. I have been playing with, err um, working with it for the last four hours and I'm sure I could still tweak it a bit more. Here is a graph generated at the beginning to use as a baseline. ![]() Here is the same setup with the filters applied ![]() Here are the waterfalls for each No filters ![]() With filters ![]() And decay, in the same order ![]() ![]() Here are the filters I applied ![]() I'm thinking everything is looking better and not too bad for my first pass and about 45 minutes of work but wait... ...Here's what happened when I added the mains to the mix. ![]() Not looking as good now. Hmm. So I tried all the tips I have read on here; adjust the phase on both subs (individually and together in every possible combination), and adjusting the distance settings. All I got from this ~2 hours of work was an even worse looking graph. I just moved the dips and peaks around. So I started over with a single sub on (the one in the right rear corner). Here is the starting point ![]() ![]() ![]() And here is what I ended up with using a house curve also applied (30 8, 80 0). ![]() ![]() ![]() And here are the filters I applied ![]() I did some quick tests of the system after I finished up with this last round of adjustments. Here's what I demoed for the listening tests.
My initial impression of this setup is WOW! The bass seems to integrate much better with the rest of the speakers (more seamless) and seems to hit much harder. I can't imagine what it would be like with a little more extension. Surprisingly, at least to me, was how much better the surrounds came alive with the filters applied. I am already glad I found REW, this forum and bought a BFD. I am sure it is only going to get better not to mention I have a new sub coming soon. It will be interesting to see what the new single 15" sub (Elemental Designs A5 - 350) sounds like compared to my two 10" subs (Paradigm PW-2100). I'm going to bed in a few minutes but I will continue to mess around with it tomorrow after work. Your thoughts and suggestions are welcome of course. I would really like to get it smoothed out with both subs and the mains. I'm not sure what I should be doing to get rid of the dip from ~50Hz - ~100Hz when I add the mains (graph 7). I'm thinking my time could have been better spent just continuing to work on getting that dip worked out with both subs. I'm definitely getting deeper extension in that configuration. | |||
| | #2 (Link) | |||||
| Re: My first session with my new FBQ2496 - Results inside... Congratulations! Quote:
ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||||
| | #3 (Link) | ||||
| Re: My first session with my new FBQ2496 - Results inside... Quote:
brucek | ||||
| | #4 (Link) | |||
| Re: My first session with my new FBQ2496 - Results inside... Yes you are correct Brucek, but generally when spending money on new subs, I would seek higher quality and also higher SPL levels (as an upgrade). If this is the case, I think a single 15" driver won't be too much of an improvment (SPLwise). ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #5 (Link) | ||||
Based on what I have listened to it seems like a good 15" sub does provide more of that intense hit you in the chest slam than one or two 10" subs of ~equal quality are capable of. Is this correct? Shouldn't I expect the new sub to accomplish these two goals? I'm not really debating this topic. My questions are more along the lines of asking for input on the topic. I'm a little concerned now that I will not be getting the results I had hoped to achieve with this change in subs. | ||||
| | #6 (Link) | ||||
brucek | ||||
| | #7 (Link) | ||||
If you look for more punch (midbass), so you need more SPL, a 15" will have more puch, two will rock! ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #8 (Link) | ||||
I would love to have two of the 15' subs but I really don't have room for a second one in this room. In fact, I have only one location to place the one of them. I guess you could say I am space challenged in this room. I did a demo for my wife tonight to get her opinion on the sound/feel of the system after adding the EQ. It is an understatement when I say she was pretty skeptical leading up to this demo. She wasn't real keen on the idea of replacing two "perfectly good and working" subs with a new one and she was equally baffled by the purchase of an EQ for subs. Let's just say she had pretty much made her mind up that it was the EQ was a silly purchase and here expectations were pretty low. I played the same clips I used to test system last night (listed in my first post) except for the SACD but I added a few others for this session. The additional things we watched were:
I also listened to a few more clips (Some of the other good bass passages in Monsters Inc. and the scenes from War of the Worlds - the lightening storm and when the walker things come out of the ground and start blasting people) by myself. I can not stress how blown away I am with the improvement in not only the bass performance but in the overall sound improvement of my system after adding this EQ. I do have things vibrating in the room now that I need to track down and eliminate but I'll tackle that once I stop grinning. I still want to add the other sub back in and get the system dialed in with both but I think I will enjoy it as is for now and just watch a couple movies this weekend. I may just leave the other sub out of the mix since I should have the new sub by the end of the month anyway. I will be starting all over then anyway. | ||||
| | #9 (Link) | ||||
Nice that your wife was able to tell a difference... Regards, Wayne | ||||
| | #10 (Link) | ||||
It is very nice that she notices the difference and is actually liking it. We watched Fantastic 4: Rise of the Silver Surfer tonight but I played a couple scenes from WoW for her beforehand and she was blown away. The Silver Surfer movie was a bit of a disappointment btw. Here's what I'm talking about with the difference in the starting points with the subs in the three configurations I described. The red line is with the two subs in opposite corners, the green line is both subs stacked in the right rear corner, and the red line is a single sub in the same rr corner (the current setup). There are no filters applied to any of these measurements. ![]() BTW, do you guys see anything I should be doing differently with the filters I have applied? Thanks for all of the input. It is very much appreciated. | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Success with FBQ2496 | OvalNut | BFD Forum | 22 | 09-26-07 11:28 AM |
| Advise on Heat Build up inside TV .... | salvasol | Video Displays and Processors | 3 | 03-21-07 06:02 PM |
| FS: Behringer FBQ2496 | Josuah | Classifieds - Equalization and Calibration Equipment | 1 | 11-13-06 03:35 PM |
| Whoa! Inside The Apocalyptic Brick?Scary! | Roger | Movies | TV Shows | Hollywood | 0 | 08-28-06 11:53 AM |
| FBQ2496 | bobgenie | BFD Forum | 5 | 06-02-06 04:05 PM |
