Input conversion? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Input conversion?
Discuss Input conversion? in the Subwoofer Equalization | Calibration forum; Input conversion? Hello! I am about to start using a 'pro' amp for my DIY subs. Up until now I've used an ...
Old 03-06-08, 04:42 AM   #1 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
Input conversion?
Hello!
I am about to start using a 'pro' amp for my DIY subs. Up until now I've used an SVS PB12+/2, which have single ended inputs. My pre also have single-end output. The new pro amp (EP2500) have balanced (XLR) inputs. Will the BFD accept single ended input and output balanced? I realize of course I won't get the full benefit of a balanced setup, but it would save me a new cable converter.
Also, while I'm on the subject. Is it better to have the long run balanced XLR from the BFD to the amp, or have them close and run long speaker cables? I'd imagine the XLR to be better screened than the speaker cable, but the speaker cable is higher level...
My DIY build Status: Almost done.
My room thread
Old 03-06-08, 05:03 AM   #2 (Link)
Alias: Tone
Loc: Birmingham UK
User: #16287
Since: Feb 2008
tonyjover is offline
Re: Input conversion?
atledreier wrote: View Post
Hi,
Long XLRs over long speaker cables every time. Voltage levels, and hence current, and hence voltage drop are all miniscule in signal cables; the opposite is true for speaker runs. Always keep your speaker runs as short as possible.
As for your other question, there's nothing particularly bad about going unbalanced to balanced, just ensure that the cables are correctly wired - many aren't. See this thread.
Tony
Old 03-06-08, 05:14 AM   #3 (Link)
Alias: Maverick
User: #7168
Since: Mar 2007
Thanks alot! Bummer though, XLR cables are pretty pricey...
My room thread
Old 03-06-08, 08:22 AM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Maverick,
How long of a cable run are we talking about? Tony is technically correct, and that’s the way you see things done in a pro-audio installation. But in a home theater the cable runs are rarely long enough to make a difference. For instance, the speaker wire runs for my subs and front mains are over 30 ft., which would not be considered long in a pro-audio installation.
There’s another issue you won’t see addressed much that I feel is important as well. As you note, long balanced cables aren’t cheap, so the urge will be there to get the cheapest ones you can find. Wouldn’t want to see you do that. As an experienced cable builder I’ve cut open plenty of them, and I can assure you, you don’t want that junk in your system. Equally as bad as the poor build quality of the cables is the cheesy off-brand XLR connectors they use.
Bottom line, I’d rather see you use decent-quality shorter cables in your equipment rack, with Switchcraft or Neutrik XLRs, with a long speaker cable run, than cheap balanced cables with “correct” short speaker cables.
Old 03-06-08, 08:40 AM   #5 (Link)
Alias: Maverick
User: #7168
Since: Mar 2007
we're talking runs of about 10m (30'). I have my BFD in the same rack as my pre. So I was hoping to run balanced from the BFD to the amp in the adjacent room, then speaker cable back to the subs. I'll have to experiment with positioning first and see what cable length I end up with. I've read that many have problems with hum in their BFD. I have no such issues. Might I introduce hum with a balanced run in the loop?
My room thread
Old 03-06-08, 09:24 AM   #6 (Link)
Alias: brucek
User: #6
brucek is online now
Yes...........
Old 03-06-08, 09:38 AM   #7 (Link)
Alias: Maverick
User: #7168
Since: Mar 2007
ok, thanks!
My room thread
Old 03-06-08, 10:56 AM   #8 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Balanced signal runs don’t introduce hum. If you get it, the source is elsewhere.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Conversion of IB to LLT Bob_99 DIY Subwoofers - Infinite Baffle 24 04-03-08 07:39 AM
No input Tom Edward REW Forum 29 01-12-08 10:08 PM
Input on new setup Fezzy Home Audio Speakers 8 04-16-07 11:08 AM
What to use for input Mopar_Mudder REW Forum 4 02-07-07 03:19 PM
Max Sub Input Gizmo BFD Forum 2 12-29-06 03:01 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
