Difference between +4db vs -10db input level - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Difference between +4db vs -10db input level in the Subwoofer Equalization | Calibration forum; Difference between +4db vs -10db input level I've read in the setup guide that it is highly recommended to use the -10dB (home) input level on the ...
Old 11-19-07, 12:30 PM   #1 (Link)
Alias: lovingdvd
User: #5942
Since: Jan 2007
lovingdvd is offline
I've read in the setup guide that it is highly recommended to use the -10dB (home) input level on the BFD instead of the +4 dB setting (studio).
When I first set up REW/BFD months ago I accidentally had the switch in the +4 dB setting and didn't realize it until well after I was done calibrating the filters and getting everything set up just perfectly. Not wanting to mess with an otherwise perfect setup I just left it that way.
Fast forward several months to the present and I now have a new receiver and therefore went through the complete REW/BFD setup again from scratch. This time I did so at the -10 dB setting since I knew it was recommended.
However I am trying to understand exactly just what difference the +4db versus -10db setting actually makes. For instance when I look at the lights on the BFD showing the input level, they do not seem to change at all based on the +4 vs -10 setting. So when I play a loud passage with deep LFE bass say it flashes orange at loudest part with +4db. When run with -10db it gives the same exact reading with the lights.
So what difference is this setting actually making? It does not appear to affect the input or output of the sub, but I'm sure there is a notable difference here somewhere - just trying to understand what that difference is.
On a related note my bass does not have as much 'thump' with music as it did with my last configuration despite having about the same response curve and house curve post calibration. Is it possible this setting is playing a part in that?
Thanks!!
Old 11-19-07, 02:50 PM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: Difference between +4db vs -10db input level
Normal home usage receivers (AVRs) use the nominal line output level convention of -10 dBV so IMO best to use that into the BFD. Less chance of having your receiver output clip. The BFD should output a nominal +4 dBu pro level to a downstream amplifier.
Old 11-19-07, 03:12 PM   #3 (Link)
Alias: lovingdvd
User: #5942
Since: Jan 2007
OK, I think I see now. This is dbV, not db? Not that I know what dbV is necessarily but then this is not a measure of the actual loudness like db would be?
Old 11-19-07, 05:43 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
The two operating level switch settings are -10dBV and +4dBu.
The 0dBV reference level is 1 volt and the 0dBu reference level is 0.775 volts.
The switch doesn't change the level or affect the signal that it passes in any way through the unit. It simply changes the operating level.
Send a continuous peak signal sine wave from REW into the BFD with the switch set at -10dBV and then switch to +4dBu. You will see the LED indicator LED drop quite a bit....
Old 11-19-07, 06:28 PM   #5 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is offline
I changed mine the other day after seeing red clip lights on the BFD. It was my (wrong) assumption that this would attenuate the input level and require more gain from the amp to achieve the same volume and this is how the BFD gained headroom. WRONG!! I clipped my amp.
Running noise to the sub and switching back and forth between the settings there was no difference in output level. Apparently just the internal processing levels are different.
Old 11-20-07, 07:43 PM   #6 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Yup – it’s internal. Some equalizers have a switch separately for the input and output, and those will make an audible difference in level if you switch one but not the other.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
BFD Input Level? allredp REW Forum 30 04-01-07 01:10 PM
Input Level -4/-5, ok? daxie BFD Forum 4 01-22-07 11:49 AM
input level, and roll off eddthompson REW Forum 9 08-23-06 07:10 PM
Input Level Warnings rsachs REW Forum 1 08-05-06 05:32 AM
About on level keyboard key -10db/+4db Ronaldo Cocuroci BFD Forum 3 07-21-06 06:13 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
