Initial measurements...opinions requested - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Initial measurements...opinions requested in the Subwoofer Equalization | Calibration forum; Initial measurements...opinions requested Hello all. Long-time lurker, first time poster. So this weekend I sat down with my Ratshack Digital SPL, RoomEQ and ...
Old 02-04-08, 11:36 AM   #1 (Link)
Alias: g3kko
Loc: Green Bay-ish, WI
User: #1457
g3kko is offline
So this weekend I sat down with my Ratshack Digital SPL, RoomEQ and my BFD that's been gathering dust on a shelf since I picked it up on eBay 2 years ago. Long story short, my laptop seems to hate RoomEQ, so I fell back on the "subtest" XLS and some 1/6th octave tones. Check it out:
These three measurements were for the left, right & center cushions of the sofa. The 63hz suckout in the "sweet spot" was mighty strange to hear. I placed my head there after running the measurement, and I could literally hear the null come and go moving my head side-to-side by 6". Don't know how worried I am about that one, but if I can get rid of it, I want to. That's where I sit.
All in all, I'm pretty pleased with how things turned out just as they are. A bit depressed that I don't have more below 25hz, but I'll cope. Do I even bother with the BFD? I'm thinking "maybe", just to pull down the 50hz region a bit. Makes sense that there's a hump; my sub has an Le of 3.5mH and a peak there is common with high-inductance subs. Otherwise, I have the ability to place the sub directly behind the sofa. I know that, for higher frequencies, one can swamp room interactions by being extremely nearfield. Does the same thing apply for purely pistonic subwoofers?
Here's the room layout if anyone has bright ideas. Basement with a 7-1/2' ceiling. The left wall is a half-wall in the front half of the room and that "wall" to the right of the TV is actually a 25" high box that hides the water main. I wouldn't trust my 150LB sub not to shake the thing apart, so no putting it up there. :-)
Again, I think I'm actually doing fairly well right now as it is. But maybe you guys see something blatant that I've missed. Any help or ideas are greatly appreciated.
Thanks!
Old 02-04-08, 12:45 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Initial measurements...opinions requested
I would say no, but I'd sure like to see an REW plot.
The dip at 63 Hz may display as a much sharper spike in REW rather than the dip you're showing, simply becuase of the difference in resolution from the manual method.
I wouldn't consider 3.5mH that high an Le, and suggest the 50Hz peak is more likely a standard room mode resonance.
I would try a bit of movement with the sub along that wall if possible and take a few measurements. Certainly painful using the manual method, but easy with REW.
I would work on getting REW working (unless of course that laptop is MAC). Hopefully you had a line-in connection or an external USB soundcard and weren't using 'mic-in'..... Some people also have a bit of trouble with Vista.
Old 02-04-08, 01:23 PM   #3 (Link)
Alias: g3kko
User: #1457
g3kko is offline
brucek wrote: View Post
Thanks, Bruce.
It's an HP nc6220 (HP's "business" line). I checked the manual for it, and while labeled "mic in", it is stereo-capable and warns that certain microphones will have insufficient signal. I initially took that to mean that it was as good as a line-in. Seems not.
I just couldn't get the thing to calibrate. I couldn't get the IN & OUT levels to match, and when I got them close, the resulting calibration measurement was clipped. No worries; I may be able to get a sufficiently quiet PC within range.
Old 02-04-08, 02:10 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, your description of how it went for you says that it was a mic-in and shouldn't be used. You need a line-in.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
PB13-Ultra Initial Impressions Aetherhole SVSound 25 01-03-08 06:21 PM
feedback requested on HDTV recording server benogil High Definition | HD DVD | Blu-ray 4 11-10-07 01:34 PM
My initial results genesis471 REW Forum 18 08-24-06 07:01 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
