| BFD Forum does anyone use the Hd 400 to get rid of humDiscuss does anyone use the Hd 400 to get rid of hum in the Subwoofer Equalization | Calibration forum; does anyone use the Hd 400 to get rid of hum Hi does anyone use, or have experience of the Behringer Hd 400
(hum destroyer) to get rid of the dreaded ... |
| | #1 (Link) | ||||
| does anyone use the Hd 400 to get rid of hum Hi does anyone use, or have experience of the Behringer Hd 400 (hum destroyer) to get rid of the dreaded hum on the bfd. I only have a little hum left after removing the ground wire in the xlr input but would like to get rid of the rest without degrading the signal. I understand the hd400 changes the unbalanced input into balanced but wonder does it need changing back again to unbalanced for the subs which may require two hd400 s. Any help appreciated Thanks | ||||
| | #2 (Link) | ||||
| Re: does anyone use the Hd 400 to get rid of hum Actually, I believe people have had better luck by using the Art CleanBox II. It has very good low frequency response, which you want with a subwoofer. The HD400 doesn't publish its specs, so you don't really know how well their transformer extends into the sub range. brucek | ||||
| | #3 (Link) | ||||
| Re: does anyone use the Hd 400 to get rid of hum Hi thanks for the quick reply. Im not sure if we can get those in the uk, but will do a quick google search. Thanks again, also for the other great info you have written, its very interesting. Regards steve | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Axiom m80 v2 (400w) vs Amp 400> | alexadams77 | Home Audio Speakers | 11 | 01-13-08 02:47 PM |
| New Reciever: $400 budget | bamaboy | Home Theater Components | 8 | 01-01-08 01:32 PM |
| HT Hum | Spakman | General Discussion | 5 | 11-30-07 11:53 PM |
| Can't get rid of peak at 80Hz | mixello | REW Forum | 1 | 09-08-07 03:20 AM |
| Which receiver under 400? | chopperguy99 | Home Theater Components | 15 | 08-30-07 10:13 PM |
