| BFD Forum No Input Levels AT ALL!Discuss No Input Levels AT ALL! in the Subwoofer Equalization | Calibration forum; No Input Levels AT ALL! Hi, I joined this forum quite awhile ago, but this is my first post. I purchased a BFD almost a ... |
| | #1 (Link) | |||
| Hi, I joined this forum quite awhile ago, but this is my first post. I purchased a BFD almost a year ago, but am first trying to set it up tonight! I connected it via RCA to 1/4 inch adapters. Then, STEP 1 of the BFD Guide is setting input levels. I cannot get ANY LED's to light up while playing U-571.I am using a Hsu VTF-3 HO and MBM-12. I am splitting the output after the BFD. I tried Input/Output 1 and 2. Neither worked. I am getting a weak signal to the subs. I basically had to turn both up to the max level, and set the sub level on my receiver, Denon 2807, to +12. Something is not right, here .Is this a case of a faulty BFD, or am I doing something wrong? Thanks in advance for any help! | |||
| | #2 (Link) | ||||
| Re: No Input Levels AT ALL! Quote:
Nick | ||||
| | #4 (Link) | |||||
| | #5 (Link) | |||
| Re: No Input Levels AT ALL! Start by setting all the filters to the OF mode. Then all the filter LEDs will be un-lit. Then disengage BYPASS so the IN/OUT LED is on solid. Does it pass the signal fine to the sub? brucek | |||
| | #9 (Link) | ||||
| Re: No Input Levels AT ALL! Ahh, OK, I thought from this response to my question that it was good in bypass. Quote:
Also be sure of the Input and Output channel connectors - they're easy to get mixed up.. brucek | ||||
| | #10 (Link) | |||
| Re: No Input Levels AT ALL! INPUT Denon Subwoofer out>RCA splitter>RCA cable>RCA to 1/4" converter (Y adapter)>BFD Input 1 OUTPUT BFD Output 1>1/4" to RCA & adapter>separate RCA cable to sub & MBM | |||
| | #11 (Link) | |||
| Re: No Input Levels AT ALL! I tried reversing them. You know, just in case. I also tried using Input/Output 2, as well. I have also tried sending other signals besides the subs (center channel, front left). I cannot get a single LED to light up. | |||
| | #12 (Link) | ||||
brucek | ||||
| | #13 (Link) | ||||
What's a TS? | ||||
| | #14 (Link) | |||
| Re: No Input Levels AT ALL! Hey, I tried unhooking one of the two RCA inputs. Since my 1/4" plug into the BFD is stereo, I thought it would (somehow) be best to feed both R&L signals. Apparently the BFD rejects a stereo feed into a single input...? Because, when I send either the right or left channel signal to the input, IT WORKS!!! Thanks for all the help ! Did I find a new way to screw things up, or have you heard this problem before?Ummmm, you don't need to answer that . | |||
| | #15 (Link) | ||||
Why not try a single RCA cable to the input of the BFD to see if it works?. To convert from RCA to 1/4" phone at the BFD itself you need a simgle (RCA to 1/4" TS adapter). TS stands for Tip-Sleeve, as opposed to 1/4" TRS, which stands for Tip-Ring-Sleeve. A TRS won't work. See the picture below: The bottom one is TS and the top is TRS. Is your adapter TS? brucek | ||||
| | #16 (Link) | ||||
Now... what are the odds I have the right equipment to run REW? Actually, it looks like I've got that covered! Thanks again. I've got more work to do tonight! | ||||
| | #17 (Link) | ||||
By removing the ring signal it will work because there would now be a difference. You wouldn't obtain the proper level though since the auto servo level function isn't invoked because the ring and sleeve aren't shorted to indicate an unbalanced connection So you really need to get one of these. It is a (RCA to 1/4" phone TS adapter). ![]() Also be sure that when you get the adapter for REW to plug into the line-in and line-out of the soundcard you get a (stereo 1/8 " phono to RCA splitter). ![]() brucek | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Bass Levels | Mongrel714 | System Setup and Connection | 5 | 08-10-07 05:12 PM |
| Check levels with Sub Problem | avaserfi | REW Forum | 5 | 07-20-07 08:59 AM |
| Setting Levels in SW | Anthony | DIY Speakers | 2 | 07-17-07 08:19 AM |
| O'scope for amp levels | jokers10 | Home Theater Components | 5 | 03-03-07 02:53 PM |
| Can't get the BFD input levels up high enough | monomer | BFD Forum | 9 | 12-21-06 11:58 PM |
