Should I have bought the FBQ2496 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Should I have bought the FBQ2496 in the Subwoofer Equalization | Calibration forum; Should I have bought the FBQ2496 I recently purchased a DSP1124P. I wanted to keep things simple, and easy on the wallet. But now I am ...
Old 01-05-08, 09:45 AM   #1 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
I recently purchased a DSP1124P. I wanted to keep things simple, and easy on the wallet. But now I am thinking I messed up. I need you guy's advice to make sure I make the correct decision.
First, I am running 3 subs for now. Subs are HSU VFT3 HO w/Turbo, HSU MBM-12 and the HSU VTF3 MKII. Now I realize that the 1124P only has 2 outputs. But my thinking was that I could combine the HO and MBM on the same output, and use the other output for the MKII.
The HO is handling everything from about 50hz and below, the MBM is taking over everything from 50hz to 80hz. So these two are not sharing any frequency's together. Plus they are located right next to each other.
Am I wrong in thinking that I can run the 1124 this way? Should I return the 1124P and buy the FBQ2496?
Thanks in advance!
Nick
Old 01-05-08, 10:17 AM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Should I have bought the FBQ2496
I don't see the difference an FBQ would make over an 1124P. They're both two channel devices.
Which seems a perfect recipe to have them on one channel of filters together as you planned. Why do you not like this idea?
Maybe I don't understand the crossover situation. I figured that the processor must use a standard cross at 80Hz and then the mid bandpass crossover for the MBM would be internal to the sub itself and then some sort of LPF filter around 50Hz for the HO?
Old 01-05-08, 10:26 AM   #3 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
brucek wrote: View Post
I thought the FBQ had more outputs?
Which seems a perfect recipe to have them on one channel of filters together as you planned. Why do you not like this idea?brucek
I thought the FBQ had more outputs, so each sub would deserve it's own output, and each it's own set of filters. Since both models only have 2 outputs, it voids my worry
Processor set at 80hz. MBM cuts off at 50(80-50hz)
HO crossover set at 50hz, then handles all it can below that point.
MKII is set for 50hz as well, but I may bump that up to 80hz and see if it makes a difference.
Old 01-05-08, 10:47 AM   #4 (Link)
Alias: brucek
User: #6
FBQ2496
OK, just as I had thought then. So why do you not like these two on the same channel? The BFD can create 12 filters per channel of any frequency, gain, bandwidth.......
Old 01-05-08, 10:58 AM   #5 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
FBQ2496
I was just thinking they needed their own channel, thats all. No worries. My original plan was correct.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Bought the Epson 1080p Thomato Home Theater Projectors 5 05-12-08 10:00 AM
I Bought Some Cheezy Component Vid Cables yourgrandma Remotes | Cables | Accessories 10 01-05-08 08:13 PM
Just bought a ClearPlay DVD player JorgenMan Home Theater Components 3 12-04-06 01:36 PM
FBQ2496 bobgenie BFD Forum 5 06-02-06 04:05 PM
Bought an amp! FlashJim Home Theater Components 5 05-22-06 09:38 AM
Mach 5 Audio
