Got an idea, and have a question for BFD users - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Got an idea, and have a question for BFD users in the Subwoofer Equalization | Calibration forum; Got an idea, and have a question for BFD users Hi. Having succesfully used the Behringer DSP 1124 on my PB12+ sub and being so impressed with the results I ...
Old 01-12-08, 11:17 AM   #1 (Link)
Alias: claus_dk
User: #9824
Since: Jun 2007
clausdk is offline
Hi.
Having succesfully used the Behringer DSP 1124 on my PB12+ sub and being so impressed with the results I was beginning to wonder if it is adviseble to also use a Behringer on the main speakers?
Challenge:
Moving into a new house and I am possibly buying Vienna Acoustics Strauss main speakers. They sport 10" woofers and can play fairly deep. However I will have little or no control over that bass, since my AV reciever has poor built in EQ. It's a pioneer AX2. Seing as they can play fairly deep it's my plan to crossover at around 40-50hz. I can use my current Behringer to reduce peaks then from 50hz down, which is all good, but then I'm left with no bass control from 50 hz and up....
So I thought, what about adding a second Behringer! I use my pioneer reciever as pre amp only since I recently bought a Primare A30.5 power amp. I could then plug in another Behringer between the pre out on the pioneer and the power amp.
Is this a good plan or should I go a different route?
/claus
Old 01-12-08, 12:42 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Got an idea, and have a question for BFD users
Is this a good plan
You are subjecting the mains signal to a conversion from analog to digital, through a DSP, phase changes from filtering, and then from digital back to analog. All this to control a very narrow bandwidth of bass. Do you think it's worth it? Will the signal to noise, dynamic range, and soundstage be better or worse after the conversion? (remember, this is a hundred dollar device you're passing your pristine mains signal through).
Old 01-13-08, 06:12 AM   #3 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Hi Claus,
We see this quite a bit, folks with highly-capable mains who feel their speaker’s capabilities are somehow going to waste if they don’t utilize every last Hz of extension.
In actuality, you’ll get better overall sound quality if you just use the receiver’s crossover and hand off the bass to a subwoofer at the usual 80-90 Hz. This gives you full control of the bass frequencies, as far as equalizing goes.
Old 01-13-08, 06:14 AM   #4 (Link)
Alias: claus_dk
User: #9824
Since: Jun 2007
clausdk is offline
Ok thanks for the input so far.
At any rate, I'm going to test it out once I move into the house. Using different crossovers and measure with REW - it's going to be loads of fun
I'll just use my current Behringer on the PB12+, which so far has proven very good.
Old 01-16-08, 09:12 AM   #5 (Link)
Alias: Robin Hood
Loc: Sherwood Forest
User: #11451
Since: Sep 2007
stephenb1 is offline
Hi
what about modifing the speakers so the 10" woofers have their own amp,
this will produce better control and power and then a bfd wont affect the overall sound too much while being equalised.
I have three ways and while the extra sub bass is welcomed it can bit a little too much will all the extra bass from the main subs when loud.
Why not try a dcx2496 if its as clean sounding as the bfd, it should be a good help with auto phase alignment, delay and parametric eq 's.
Mines on order looking forward to it arriving.
Old 01-16-08, 09:36 AM   #6 (Link)
Alias: claus_dk
User: #9824
Since: Jun 2007
clausdk is offline
I have a pretty decent seperate power amp for the mains, which I'll use. Once I move into the new house, I'll do some measurements, and I'll surely remember to post'em here!
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
BFD delay question mixello BFD Forum 12 03-29-08 12:14 PM
BFD Connection Question drrick BFD Forum 9 12-27-06 08:46 AM
H/K and BFD question wmilas BFD Forum 5 08-30-06 11:25 AM
BFD Hookup Question rolyasm BFD Forum 13 07-22-06 12:08 PM
BFD Question Newfiestang50 BFD Forum 13 05-15-06 07:18 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
