| BFD Forum FBQ 2496 output is flat after power off/onDiscuss FBQ 2496 output is flat after power off/on in the Subwoofer Equalization | Calibration forum; FBQ 2496 output is flat after power off/on I have a problem with FBQ 2496. After power off/on filters are not in use. Output response is flat, same ... |
| | #1 (Link) | |||
| FBQ 2496 output is flat after power off/on I have a problem with FBQ 2496. After power off/on filters are not in use. Output response is flat, same as with bypass. Front panel leds show that filters are in use and if I check those show correct values (Hz, dB etc). In order to get those taken in use I need to go and touch each filter separately. Has anyone else noticed this?. Am I doing something wrong or is this normal behavior and I need to keep power on 24/7? | |||
| | #2 (Link) | |||
| Re: FBQ 2496 output is flat after power off/on I have BFD's, but I can't imagine that the FBQ acts any different. If I power on and off, everything returns as it was before the power down. So, that would appear to be a fault to me. Most people simply leave their BFD's on all the time to avoid the annoying turn on thump. They draw less than a night light. Most equipment you own draws similar current even when shut off, so as to keep the remote capability alive. So, I wouldn't worry too much about wasting power if you choose to leave it on all the time. brucek | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Yamaha RX-V1800 and Behringer FBQ/DSP | jerome | Home Theater Components | 18 | 01-19-08 09:17 AM |
| Box Sub Output vs. IB Sub Output | NickTF | DIY Subwoofers - Infinite Baffle | 15 | 10-18-07 09:25 PM |
| fbq 2496 what else(not cables) | bis | BFD Forum | 4 | 10-08-07 04:05 PM |
| FBQ 2496 vs DSP 1124P HELP PLS | Blaser | BFD Forum | 14 | 02-07-07 02:57 PM |
| FBQ 2496 better performing then DSP1124? | rkruz | BFD Forum | 1 | 10-10-06 09:35 AM |
