Freq Boost Question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Freq Boost Question
Discuss Freq Boost Question in the Subwoofer Equalization | Calibration forum; Freq Boost Question Hey guys, I was reading that a 3db boost down low takes alot of your sub. But they said a ...
Old 02-09-08, 12:35 PM   #1 (Link)
Alias: Chris
User: #15169
Since: Jan 2008
NismoZ is offline
Freq Boost Question
Hey guys, I was reading that a 3db boost down low takes alot of your sub. But they said a higher freq boost would not tax it as much.
I have a new PB13 Ultra, so it's plenty capable; driver and amp wise...
I have a narrow 63hz null that needs about a 20 db boost. (I cannot move the sub)
How much of a freq boost @ 63hz can I ask of my sub?
Old 02-09-08, 12:52 PM   #2 (Link)
Alias: Pekka
Loc: Finland
User: #13097
Since: Nov 2007
plundstrom is offline
Re: Freq Boost Question
NismoZ wrote: View Post
3db means always double the power, it's not frequency dependence. Of course subs have less "reserve" is lower frequencies, so in that sense you need "more".
Nulls comes because of room and applying more power is little help. Better is look for new location for the sub or adding another sub to other location. REW is good tool to start.
ps. 20 db means 100 times the power. If at high play you are taking 100 Watts for other frequencies, then boosting your 63 Hz to same level needs 10 kW and even PB13 can't deliver that.
Old 02-09-08, 02:00 PM   #3 (Link)
Alias: Chris
User: #15169
Since: Jan 2008
NismoZ is offline
Can't move the sub... So, would a 10db on 63 be alright?
Just for testing, I put a 10+ db gain boost on 63hz. It brought my curve within 5db of my target. So, if I leave it at a 10db boost, what will I be hearing on movies when it hits 63 hz. A less clean sound? A chance of blowing the driver or amp?
Old 02-09-08, 02:38 PM   #4 (Link)
Alias: brucek
User: #6
brucek is online now
No......
If you boost the signal at 63Hz by +10dB and it's not clipping the BFD's output, it means that the maximum input level that you've setup into the BFD is obviously -10dB down from the maximum allowed.
Why is that?
Old 02-09-08, 10:54 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
I believe all SVS subs have built in limiters, and from what I’ve seen with the few I’ve had the opportunity to use they work very well. So there is little danger of doing any permanent damage to your sub. IOW, the electronics will compress the signal at 63 Hz if it tries to run higher than the amp’s capabilities. The audible effect will probably be a sudden, momentary reduction in signal level – at least that’s what my experience with SVS has been.
That said, depending on how narrow your null is it probably isn’t audible anyway, so it may well be a waste to try to equalize it at all. We’d be able to better tell if you’d post a graph here.
Old 02-10-08, 09:44 AM   #6 (Link)
Alias: Chris
User: #15169
Since: Jan 2008
NismoZ is offline
The width of my 63 filter is 1(smallest) in bandwidth... So it may not effect me to leave the deep null alone...
This is a graph of what I have so far... Blue being before BFD, red being after filters placed. As you can see I have inquaged a +10 gain on 63hz and +4 gain on 90hz to bring some nulls up. This is at -35 vol. I normally listen to movies at -25, no more then -20... So, should I keep those +gains or take em out?
Old 02-10-08, 04:44 PM   #7 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
I’d ditch the 63 Hz one. Anything that requires a 1/60-octave filter shouldn’t be equalized, especially upwards. Just to give you some perspective of how narrow that is, there are only 12 musical notes in an octave (i.e. 1/12-octave).
By the way, hope you aren’t EQing any frequencies above your sub’s crossover point.
Old 02-10-08, 05:26 PM   #8 (Link)
Alias: Chris
User: #15169
Since: Jan 2008
NismoZ is offline
My Pioneer 811S AVR only goes to 100hz x-over. So, I can' set it at 80... Will be fixed on next AVR upgrade Would you keep the one at 90?
Old 02-10-08, 05:29 PM   #9 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Yes, I would.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
recommendations for low freq sub? consfearacy DIY Subwoofers 15 12-26-07 10:27 AM
Sure would like to add some boost ..... Jawjabill REW Forum 5 08-11-07 02:18 PM
Cut or Boost? How Much mpompey REW Forum 58 02-04-07 10:50 PM
House curve...boost filter...what's the difference? tdamocles BFD Forum 1 09-30-06 01:27 PM
How much boost? toecheese REW Forum 6 05-26-06 11:46 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
