| BFD Forum Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please.Discuss Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. in the Subwoofer Equalization | Calibration forum; Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. Hi everyone great forum.........
I have bought all the items above and have a new subwoofer coming its a Bk ... |
| | #1 (Link) | |||
| Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. Hi everyone great forum......... I have bought all the items above and have a new subwoofer coming its a Bk Monolith DF.....i have read some of the sections about the rew and bfd and now my head is pulsating around the 15hz region ............the sub will not be here for a couple of weeks so in the mean time whats the best way for me to prepare myself before setting this gear up for real.........big thanks in advance. | |||
| | #4 (Link) | ||||
| | Re: Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. Quote:
Regards, Wayne | ||||
| | #5 (Link) | |||
| Re: Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. hi a couple of questions......1/ i've plugged in the ecm8000 mic into the audyssey instead of the standard mic that comes with the onkyo rs605 and every time it its sends out a signal its saying there isn't any speakers pressent......is this because there needs to be a pre-amp to boost the signal or are the test tones given out via audyssey the wrong type. And 2/ where does the ( Audio control Richter scale half octive EQ ) fit into the sceme of things in what where trying to acheive against the Behringer 1124 and 2496 etc........is it not as good or is it on a par with the kit where using or in my case trying to use today!! | |||
| | #6 (Link) | |||
| Re: Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. I've read some more but i'm now confused....if i'm going to use the ecm8000 mic and pre-amp to take measurements , where does the m-audio uno interface come in to it all........am i right in thinking the midi is so you can connect directly to your bfd and down load the new filter settings in a faster automatic way. ..........who has a cheap sms1 for sale (ha yeah right cheap thats why i'm doing this in the first place ) | |||
| | #7 (Link) | |||||||
REW has a similar system, but since it has no “electronics” we use calibration files for the mics.Quote:
Regards, Wayne | |||||||
| | #8 (Link) | |||
| Re: Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. Cheers wyane............i took the soundcard back that i bought thinking that if i stick with the ones menstioned on here it would make things much easier.....is there such a piece of equipment that is a soundcard plus midi all in one.....like the edirol ua-101 audio interface soundcard etc. | |||
| | #9 (Link) | |||
| Re: Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. And does having the midi the bit which makes it all automated and a step up from the manual way.......if having an all in one is out of my price range because they do seem to be a bit pricy......having the 2 pieces of kit will be ok will it not. | |||
| | #10 (Link) | |||
| Re: Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. Any cheap soundcard will do if it has a line-in and a line-out. The midi connection is made from your PC's USB port using this cable. They sell around $40 for the cable on-line. brucek | |||
| | #11 (Link) | ||||
Cheers i know this but you didn't realy answer my question.........is there an all in one soundcard midi unit i can buy.....and yes i had the so called cheap soundcard but wanted to change with one of the units menstioned in the bfd/rew faq just to keep things simple.........ive more or less just found out that i need yet another piece of equipment (midi unit) but if this is whats needed to make life that much easire then so be it. | ||||
| | #12 (Link) | ||||
brucek | ||||
| | #13 (Link) | |||
| Re: Bfd , Ecm8000 , B Mic800 pre-amp , G-star 5.1 soundcard whats next please. Ok then i won't bother buying if its a case of having to fiddle which i like to do i'll fiddle away.......but i have just bought the Art cleanbox II (£25) , knowing me i'll get the hum when i hook up. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Connections to Pre-Amp | Bob_99 | Home Theater Design and Construction | 5 | 12-12-07 01:24 PM |
| Pre-BFD jitters (questions).....:) | Vader | BFD Forum | 24 | 04-20-07 07:24 AM |
| USB-Pre External soundcard | Element | REW Forum | 0 | 02-17-07 08:44 AM |
| pre-outs on MF3.5 to BFD-Pro? | Huck | HiFi Audio Components | 13 | 09-25-06 10:13 AM |
| Pre/pro + Amp or all-in-on receiver? | haver | Home Theater Components | 21 | 07-17-06 11:30 AM |
