| BFD Forum BFD keeps applying more filters ?Discuss BFD keeps applying more filters ? in the Subwoofer Equalization | Calibration forum; BFD keeps applying more filters ? Hi,
I have a BFD and i am only just getting my head around this.
I am ussing REW with ... |
| | #1 (Link) | |||
| BFD keeps applying more filters ? Hi, I have a BFD and i am only just getting my head around this. I am ussing REW with radio shack spl meter as mic have taken readings and at the moment just adjusting 2 to 3 peaks, I am using filters 17, 18, 19 and 20 which are all adjustable. When I set to run and start playing films or music the BFD starts applying more filters at 1, 2, 3 and so on. Am i doing some thing wrong, can i switch off the auto EQ filters. As a side note REW found 4 peaks and i put everyone of those into the BFD, but the play back volume was so low and lost a lot of impact, Yes i did turn up the gain on the subs but how can you check the differance with and without EQ if you have to turn up the volume on subs so much. If I sound dumb then accept my apology.... ![]() | |||
| | #2 (Link) | ||||
| Re: BFD keeps applying more filters ? Quote:
You need to set them all to OFF first and then set each one to parametric that you need. Start at filter #1. You have an auto mode set. brucek | ||||
| | #4 (Link) | |||
| Re: BFD keeps applying more filters ? I don't own an FBQ, I own BFD's, so I have never done it myself on that unit. But when you download the manual from here, it doesn't look too tough, as shown below from page 8. You need to manually set (from the front panel), all 20 filters of each channel to parametric. The 2496 doesn't come defaulted that way, you need to set it yourself. Once set, it will stay that way. Then with every filters gain set at zero, you have all filters off and in parametric mode... Now your ready to use all 20 filters without them doing crazy stuff in auto mode. 2496.jpg brucek | |||
| | #5 (Link) | |||
| Re: BFD keeps applying more filters ? Hi Brucek, Thank you for your help on this, I did read that part but did not make sense to me ![]() I have two PC Ultras and I do find it allot of fun messing around with REW/BFD, though my wife says iam a bit sad... ![]() Regards | |||
| | #6 (Link) | |||
| Re: BFD keeps applying more filters ? I saw the same happening with my FBQ, and what I did was to press the "Freeze" button after assigning my 3 PEQ filters. From what I could read from the manual this is supposed to freeze the auto filters? So I have not set all filters to be PEQ filters but used the freeze command. Can someone confirm that this is ok? Or is it still doing stuff in the background? (I have only had FBQ for a couple of days) | |||
| | #8 (Link) | ||||||
But you don't need to switch a lot between eq and uneq. to figure out how much improvement was made. Put a track with lots of variation in bass notes and you'll immediately note the difference. There is another trick I can tell you but many will disagree with me. To raise the level of your sub to be as loud as without eq., you can put a very wide filter (10 octaves for ex) centered at say 40 Hz and boost with the amount you need to match the uneq. sub level. While this may involve some negatives (that I won't tell you), my (good I think) ears cannot catch any difference. Quote:
![]() Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Nubee need help w/ eq filters | miltcharlie | BFD Forum | 1 | 12-30-07 09:00 AM |
| BFD filters nothing like predicted response. | StephenP | REW Forum | 3 | 08-20-07 09:24 AM |
| SPL calibration after applying house curve...? | Vader | Home Audio Subwoofers | 5 | 05-21-07 11:56 PM |
| Adding EQ filters for my EQ | legierk | BFD Forum | 5 | 04-16-07 04:24 PM |
| BFD 1124 & 24 filters: howto? | fastleo63 | BFD Forum | 3 | 10-25-06 10:10 PM |
