What does a beginner have to purchase to start using BFD? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss What does a beginner have to purchase to start using BFD? in the Subwoofer Equalization | Calibration forum; What does a beginner have to purchase to start using BFD? Hi, Let me start by saying I am always open to improve the acoustics of my listening environment, and I ...
Old 03-04-08, 09:42 PM   #1 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is offline
Question What does a beginner have to purchase to start using BFD?
Hi, Let me start by saying I am always open to improve the acoustics of my listening environment, and I am quite curious about the benefits of the BFD. What sort of improvement should I expect? And what is the "start up" cost of getting a system geared up?
At the moment I have the Receiver and Sub, that goes without saying. My computer is an intel iMac, as well I have a MacBook laptop and an old Toshiba Satellite laptop. A tripod as well for my meter when I find one. That is it so far when it comes to my preparedness fro subwoofer "EQing". I live in Canada, so my access to a Radio Shack meter is non existent. The only one I could find nearby at a music store was a Galaxy 130 SPL meter (blue one) for $70. Still haven't purchased anything as I am not sure what will do the job properly with Room EQ wizard.
So from there if someone could point me in the right direction, I'd love to get started on this. Thanks!
Old 03-05-08, 05:49 AM   #2 (Link)
Alias: stephen
Loc: England
User: #16723
Since: Feb 2008
mojogoes is offline
Re: What does a beginner have to purchase to start using BFD?
I would also like to know what is the bear minimum equipment you can use to get some form of results with REW.......could i use just my laptop (samsung) and a R/S spl meter.........or definetly a soundblaster 24 or mp3+ as a bear minimum......
Old 03-05-08, 07:49 AM   #3 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Rambo4 wrote: View Post
Use the Toshiba – people seem to have trouble using REW with Macs. Pass on the tripod – you don’t really need it. The Galalxy 140 is the recommended meter if you can’t find the RS meter – in fact, by most accounts it’s better than the RS meter. Check our SPL Meters Forum and you’ll find plenty of reading on the 140.
mojogoes wrote: View Post
The “Getting Started” section of the REW Online Help Files will get you guys headed in the right direction.
Old 03-05-08, 07:53 AM   #4 (Link)
Alias: brucek
User: #6
brucek is online now
The REW HELP FILES will fill you in on everything you'll require.
The Canadian distributer of SVS subwoofers is SonicBoomAudio and they sell the Radio Shack meter. I believe it's in Markham. You can order the Radio Shack meter from them here.
Laptops usually require a cheap external USB soundcard, since they don't often have a line-in port available (mic-in is not suitable)...
Old 03-05-08, 09:05 AM   #5 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is offline
Hey thanks guys! I appreciate the info. I just wanted to make sure I wasn't going to go down a road that would require an investment of a large amount of equipment. The software to fix this is free, and for that I am grateful to this site. Compared to a lot of folks, I may have a modest HT room, so budget is a concern but if it is just a matter of a BFD and a proper SPL meter, it shouldn't be out of reach.
On the note of the Toshiba, I do have a "line in" jack next to my mic and headphone jacks. The information tells me it is integrated SoundMax digital audio. It may not be the greatest card, but I hope it does the job.
I do need EQing in a big way. The Velodyne 5000R should be plenty for a room that is 18 X 14 X 8, I just find I can either get clean bass, just not enough volume of it, or lots of bass, that "muddies up" the music. I am hoping to get "loud, clean and tight", not "boomy".
Old 03-05-08, 09:34 AM   #6 (Link)
Alias: brucek
User: #6
You can download REW and test the soundcard by doing a calibration and measure test without buying anything other than using a single cable (you must have some lying around). Use a 3.5mm stereo cable and loop line-out to line-in and test away........ No cost.
Old 03-05-08, 11:03 AM   #7 (Link)
New Member
Alias: macman
Loc: Sweden
User: #14466
Since: Dec 2007
macman is offline
I've tried all my Macs without problem, although the measuring was done with the MacBook. (G4,G5 and MacBook Intel, MacOS 10.4 and 10.5 ).
Only problem was that the Java Applet starterprogram was not the standardprogram choosen. Had to change that.
Otherwise theMacBook works ok for measure, can't get the miditransfer to work but thats another issue.
Old 04-02-08, 06:08 PM   #8 (Link)
Alias: lardawge
Loc: Maryland
User: #18769
Since: Mar 2008
lardawge is offline
I have an intel macbook and have had zero trouble using it for this purpose. It comes from the factory with a line-in and works a charm.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Sealed TC-3000, EP2500, BFD, Project Start aktiondan DIY Subwoofers - Sealed and Ported 48 03-11-08 12:46 AM
beginner questions...high pitch tone on BFD Mattlock BFD Forum 2 12-27-07 07:50 PM
Some questions before I purchase ... carel1966 REW Forum 11 08-18-07 11:38 PM
Beginner...I need help setting my system up! bpmccaff System Setup and Connection 3 02-07-07 03:11 PM
Coordinated HD-DVD purchase... Sonnie High Definition | HD-DVD | Blu-ray 16 08-19-06 10:16 AM
Mach 5 Audio
