ECM8000-how do I set it up? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Discuss ECM8000-how do I set it up? in the Subwoofer Equalization | Calibration forum; ECM8000-how do I set it up? I have an ECM8000 with UB802 on order. Looked at past posts regarding using this microphone. Seems to me there ...
Old 07-29-06, 11:49 AM   #1 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
I have an ECM8000 with UB802 on order. Looked at past posts regarding using this microphone. Seems to me there was a problem with volume that wasn't resolved. Are there step by step instuctions to use the ECM8000?
Ron Carlton
Dallas, Texas
Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo DV-981HD, Toshiba HD-A2, Cambridge Audio Azur 640C, Belkin Pure AV PF60, Behringer DSP1124P
Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Denon DVD-2200, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro
Old 07-29-06, 12:11 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: ECM8000-how do I set it up?
I recently modified a simplified REW step by step post here when I found that the poster had an ECM8000.
The modification went something like this:
(1) Hook up your ecm mic and load its calibration file. Then when you take the SET MEASUREMENT LEVEL you have your mic hooked up and then hold the RS meter beside your mic and adjust the volume of your receiver until the RS SPL meter reads 80db (then you can put the RS SPL meter down). Now the output of REW and your receiver are producing 80dB in the room.
(2) Now when you press INPUT VOLUME you have the level of your mic pre amp to play with to be sure REW is getting a level high enough to satisfy its input level requirements. This is where its different, because the RS SPL meter outputs a proper preset line level. You need to be sure your mic and preamp are doing the same thing. Adjust the pre amp and click Set Input Volume several times if you have to until REW is happy with the level.
(3) Once that's satisfied, you now have the output level in the room at 80db, and the input level to REW at the correct level, so you need to calibrate the REW SPL meter to match the needle on the RS SPL meter of 80db. Well you've already established that the room level is at 80dB, so you can go on faith the when you press CALIBRATE and REW asks you to toggle the icon until it matches the level of the RS SPL meter that you should set it to 80dB. get it?
(4) Now do TARGET LEVEL as normal
(5) Now do AUTOMATIC MEASUREMENT as normal..........
I don't know if this helps or not?
Old 07-29-06, 12:27 PM   #3 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
We'll see. Should have all the parts gathered by Wednesday. Thanks
Ron Carlton
Dallas, Texas
Old 07-29-06, 12:28 PM   #4 (Link)
Alias: Jim
Loc: Phoenix, Az
azjimmy's Avatar
User: #940
Since: Jun 2006
azjimmy is offline
rcarlton,
It really isn't to hard, and you just need to use a couple of different cables than the REW help file.
This is a picture of the mixer with the needed conections labled
Instead of the SPL meter, use the ECM8000, and mixer. Conect the Mic to the mixer via XLR mic cable. Now connect a 1/4 phone jack to the main out. I use R because the convention in REW seems to use the right in all the connections. Make sure the phantom power switch is on.
Now, just to make sure the mic is reading something, I clap my hands and watch the input meter.
You should be good to go. When you calibrate your input lever in REW, you may have to turn up the main mix a little until you get a good reading.
Good luck
Jim
EDIT Cleaned up image to make connections better illustrated.
Old 07-29-06, 01:07 PM   #5 (Link)
Alias: brucek
User: #6
Great post Jim. I'm gonna save the url for the next guy that asks about the ecm and preamp.
Old 07-29-06, 02:10 PM   #6 (Link)
Alias: Jim
Loc: Phoenix, Az
azjimmy's Avatar
User: #940
Since: Jun 2006
azjimmy is offline
Thanks Bruce,
I cleaned up the image to make it a bit more clear. Hope this is a bit better. I'm more awake now.
Jim
Old 07-30-06, 11:05 AM   #7 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
Awesome. Don't see how I can go wrong now.
Ron Carlton
Dallas, Texas
Old 08-01-06, 03:11 PM   #8 (Link)
Alias: Jim
Loc: Houston, TX
User: #425
FlashJim is offline
Great pic and explanation!! Sticky this thread.
Jim
Houston, TX
My Subwoofer Build Page
Old 08-01-06, 09:28 PM   #9 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
Got everything set up, followed the two sets of directions the best I could. Didn't work . Looked real close at Jim's settings and saw line in 1 gain set at the line just left of -10. Now everything works .
brucek...I assume your Input Volume is Set Input Volume.
Sure wish I could get the midi interface to work. I will probably have to take pictures each step of the way...I must be missing one step somewhere .
Ron Carlton
Dallas, Texas
Old 08-01-06, 10:12 PM   #10 (Link)
Alias: brucek
User: #6
Yeah, I just changed that.
Old 04-13-07, 04:51 PM   #11 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Hey guys, I followed all of the instructions here and I can't seem to get a high enough input signal. It hovers around -85db and if I yell directly into the mic it'll go as high as -30db. Of course at this point the pre-amp is clipping...I am very confused.
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 04-13-07, 05:44 PM   #12 (Link)
Alias: brucek
User: #6
Here's where my dials are to produce a proper line level output. Make sure those three EQ dials are in their zero detent positions.
The line-out of the preamp is hooked to one side of a stereo to mono adapter at the line-in of the soundcard.
Run the Check Levels routine in REW and set your AV receiver to produce 75dB on the Radio Shack SPL meter while it's held beside the ECM mic. Then put the RS meter away.
Now set the input level of the soundcard to the correct levels asked for in Check Levels routine...
No need to yell into the mic. It's quite sensitive.
That's it.
Old 04-13-07, 06:33 PM   #13 (Link)
Loc: Lower Alabama
Sonnie is offline
Also make sure your input settings in REW are set high enough. Mine reset to zero when I disconnect my sound card and exit REW. When you do your Check Levels... increase the Input Volume and Sweep Level until the Input LED is at about -12db.
Old 04-13-07, 07:29 PM   #14 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Thanks a lot guys. This is what I have http://www.guitarcenter.com/shop/pro...58&src=4WFRWXX connected to the main right output of the Xenyx with a mini cable going directly to the sound card's line-in.
My input level is always at 1.0 it appears the be the higher level. Is this ok?
Edit: It looks like I am missing the stereo to mono adapter.
oh and the phantom power feature is enabled.
Old 04-13-07, 08:21 PM   #15 (Link)
Alias: Nick
Loc: Seattle, WA
User: #7848
Since: Mar 2007
MakeFlat is offline
Exocer wrote: View Post
Use this instead:
http://www.guitarcenter.com/shop/pro...9508%2e377
That's what I use.
Nick
Old 04-13-07, 08:25 PM   #16 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
I have one of these lying around
and it seems to have done the trick.
Old 04-13-07, 08:33 PM   #17 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
MakeFlat wrote: View Post
Use this instead:
That's what I use.
Thanks a lot for that.
Old 04-13-07, 10:06 PM   #18 (Link)
Alias: brucek
User: #6
That's a stereo jack. The Preamp plug is mono. Won't work.........
You need a mono plug at the preamp that connects to the stereo adapter at the soundcard.
Old 04-14-07, 12:19 AM   #19 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
brucek wrote: View Post
Right, but adding the mono headphone jack splitter did the trick (for now). The input level is about level with the output level...Can I assume all is well?
Old 04-14-07, 10:08 AM   #20 (Link)
Alias: brucek
User: #6
No, you need the correct cables and adapters.
The preamp output is a 1/4" mono female jack - use a 1/4" mono male plug so that the contact points align properly..
The soundcard uses 1/8" stereo female jacks. It needs a stereo to mono adapter to 'break out' the two channels. You have shown one of those adapters.
Connect a single cable with 1/8" mono male plugs on either end between one channel of the adapter you have shown and a
(1/4" mono male plug to 1/8" mono female jack) adapter.
Old 04-14-07, 12:24 PM   #21 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Ah, ok.
Thanks.
The mini cables currently in use are definitely not mono cables...Looks like i have some more stuff to buy. Great
Could the following cable work as a simpler alternative?
http://www.zzounds.com/item--HOSCMP3
Of course I'd still use the stereo-mono adapter @ the sound card. But couldn't that eliminate the need for an adapter @ the pre-amp?
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
