| REW Forum EQ'ing my new IBDiscuss EQ'ing my new IB in the Subwoofer Equalization | Calibration forum; EQ'ing my new IB First post here, but have been lurking for some time. Great forum!
I have played with REW with some manual ... |
| | #1 (Link) | |||
| EQ'ing my new IB First post here, but have been lurking for some time. Great forum! I have played with REW with some manual imported readings and I greatly enjoy the interactive adjustments that can be made to the response curves. Truly a fun and useful program. Anyway, my BFD should arrive tomorrow. I am not configured to use REW to test my response, yet, but I am going to do some manual measurements and generate some filters to enter manually (for fun and to get my IB to a listenable state), while I finish acquiring the components (sound card, cables, etc.) and climb the learning curve of the program. Anyway, it sounds like manual entry will be with me for the foreseeable future because of the Midi issue with the new BFDs. I am sure there will be many more along the way, but my first questions relate to the general procedure for sub EQ'ing. Let me know if I have the general procedure right. 1. Measure response with BFD in chain (necessary?) and the subwoofer plugged in, other speakers not. During this, the anticiapted bass management settings for the receiver will be active. i.e. I will have my crossover for the mains set at 80Hz and my crossover for my surrounds set at 100 Hz. I assume this will limit the amount of EQ I will generated above my crossover, if it is not engaged during sub testing. 2 Correct my measurements with the .cal file provided on this site for my SPL meter (4050). 3. Import my corrected data into REW, checking off that I used "C weighting", which I did. 4 Set up REW as indicated in the help file, including loading my desired house curve and selecting the BFD as my EQ. 5. Find peaks and then manually tweak and adjust these peaks (I have done this already with preliminary measurements). 6. Enter the filters into my BFD. 7. Measure the response again, with only the sub active still (?). If looks good, continue on. If not, adjust filters in REW again. 8. Plug in one (both?) of front mains and measure response of main and sub together. Adjust filters, as necessary to correct peak or dip at crossover (maybe adjust crossover frequency?) Use readings to adjust SPL of sub and main speaker to achieve similar response, generating smooth curve across frequency plot. Any corrections or tips on things I may be missing would be greatly appreciated. Of course, I will post curves as I generate and tweak them. Link for my IB project, if interested: http://tinyurl.com/yd4fzd I have already used the REW to generate filters (all cuts) that really helped my curve. Hopefully they will translate to reality. I will be performing 1 Hz measurements from 10 through 100 at least to tweak my response better than 1/6 octave. Painful, yes. Worth it, I hope so! Thanks, Pete | |||
| | #2 (Link) | ||||||
| Re: EQ'ing my new IB Quote:
The surrounds have no effect here. We equalize the sub first, and then add the mains only in stereo mode to check the crossover interaction. Quote:
The crossover is usually determined by the quality of the mains (usually 80Hz). They've got to be really good to select 60Hz... Quote:
brucek | ||||||
| | #3 (Link) | ||||
Thanks for the feedback, Pete | ||||
| | #4 (Link) | ||||
Yeah, the LFE does indeed extend out to 120Hz in the Dolby spec, but my understanding is that the sound engineers roll that off themselves to integrate it more smoothly into the standard 80Hz LPF (low pass filter) crossover provided by all home processors. The actual spec'd information when given to the sound engineer goes all the way to 120Hz and then is digitally cut off. This would be horrible to listen to if sent to a sub, so I guess it's their creativity to roll it off (and a smart move). Since the 'small setting' redirected bass is normally rolled off from 80Hz (when that's the crossover you choose) at 24dB per octave, I suspect that the LFE channel is given similar roll off characteristics. At 24dB per octave, the amount of signal left at 120hZ is very, very weak. (see the graph above of the perfect sub). Myself, I wouldn't be concerned about any differences in setup because of the LFE channel. brucek | ||||
| | #5 (Link) | |||
| Re: EQ'ing my new IB If my mains are crossed over at 80Hz and my other surrounds are crossed at 100Hz, what should I use for my "cutoff" in REW? I did some quick and dirty EQ with my BFD using some old full scale measurements (no crossover) to get the feel of using it and got some pretty good results for my first attempt. | |||
| | #6 (Link) | ||||
I've thought about this myself, since I have my mains and surrounds crossed at 60Hz and my center and rear back crossed at 80Hz. I use an REW target of 60Hz since I equalize with my processor in stereo mode, that's the crossover used for that mode with the two mains. But once I have filtered with my sub only and then added my mains to check the interaction, I also turn on 6 channel stereo to see how it looks with the mixed crossovers. Seems fine.... brucek | ||||
| | #7 (Link) | |||
| Re: EQ'ing my new IB I have noticed that the plot of my manually measured data looks different than in the Excel sheet when imported into REW, with C-weighting checked as "Yes". My imported values have already been corrected, but are higher when imported into REW. Is this because of the "C" weighting? My curve slopes off in the Excel spreadsheet, but looks more level in REW. Is REW more accurate for some reason beyond the SPL meter correction factors? Do the SPL correction factors in the Excel sheet take the "C" weighting into account? Here is my plot in Excel: ![]() Here are these very same numbers from Excel plotted in REW versus my house curve: ![]() Obviously, things look better in REW, which makes sense, since I created the filters in REW. Why the difference? Am I doing something wrong? How does my curve look for sub only? I plan to tweak 25 Hz up a few dB... | |||
| | #8 (Link) | ||||||
Say no to C-weighting when you import Excel compensated readings. In fact that's the only way to do it, because if you had imported raw RS meter readings, C-Weight in REW wouldn't have been accurate because REW doesn't apply the calibration data. Quote:
Make the change to the C-weight problem and make your graph axis the same and your graphs will be identical. Quote:
brucek | ||||||
| | #9 (Link) | |||
| Re: EQ'ing my new IB OK, good point about the aixs. That does exaggerate things. The different actual values is what really threw me off. Plus the values were not off by the SPL correction values, so I figured something else was going on. I will redo my filters, not applying C-weighting on import, because I have double corrected my values to generate my filters. So, in the future, if collecting real time readings through REW, I must use the correct cal file for my SPL meter - so that REW corrects them properly? I will post updated graphs after I redo my filters with the correct data. Thanks! Pete | |||
| | #10 (Link) | ||||
brucek | ||||
| | #11 (Link) | |||
| Re: EQ'ing my new IB OK. I have almost EQ'd my sub to my mains. However, my amp is maxed out and my BFD lights up the red lights up sporadically (input level) at a reasonable loud listening volume for me on "Darla Taps the Glass". I will usually listen at lower levels, but I would like to be able to crank it up to this level or a little higher every once in a while. I could use a just a few more dBs for my sub level, but I don't want to clip the BFD. My receiver sub output level is at "0" on a -10 to 10 scale. If I switch the level on the BFD from -10 to +4, does that give me a little more headroom? Or am I not thinking straight? I am some very large cuts in the upper frequencies because of the large hump in my un EQ'd IB response. Maybe this is why I need more juice compared to people with standard subs? Thanks, Pete | |||
| | #12 (Link) | ||||
Regards, Wayne | ||||
| | #13 (Link) | |||
| Re: EQ'ing my new IB Really? Isn't it the output level. My amp is not clipping at all, it is just turned all the way up. I think I worded my last post in a confusing manner, leading you to think my amp was clipping. Of course, I am assuming that the operating level on the BFD has nothing to do with the clipping of the BFD based on the input level. I really need more sub output, but if I do it at the receiver, then my BFD will clip. I think this is an IB thing... Thanks for the feedback Wayne. Pete | |||
| | #15 (Link) | ||||
brucek | ||||
| | #16 (Link) | ||||
I had the same problem, the meters hitting red to often so I switched to the + 4 setting, and haven’t had any problems getting good readings. If the sub level is set to 0 on a –10 to +10 scale, there shouldn’t be any problem getting the level up enough, especially if it’s too hot now with the –10 setting. Regards, Wayne A. Pflughaupt | ||||
| | #17 (Link) | ||||
I have a concern with this. What happens when listening at quiet SPLs. Do you lose bass entirely if the bass content is low level? I don't think this makes sense at all. It must an issue of whether my receiver can kick out the higher line level signal during heavy bass scenes, right? I have an H/K AVR235. My loud listening level for me is -20dB on a -80 to 10dB scale. H/K's tend to have decent power supplies, so I suspect it is up to the task... Any concern with standard guitar cable style interconnects at this higher operating level? I suppose a level shifter for after the BFD is another option? I guess I will have to do some testing... Thanks, Pete Last edited by PeteD; 11-05-06 at 10:53 PM. Reason: Rethought things | ||||
| | #18 (Link) | ||||
| Re: EQ'ing my new IB The operating level switches are there to match the BFD to either consumer or Pro equipment. These two equipment types tend to output (and receive) levels within a defined range. If you discover that your receiver outputs levels that exceed the standard -10dBV operating range on the BFD, and as a result causes consistent clipping, then you have a couple options. Option 1: Reduce the receiver subwoofer output level trim until the BFD doesn't clip (at the loudest listening levels). Then adjust the subwoofer amplifier level until it matches your other speakers. If the sub amp isn't receiving enough level (a possibility with a Pro amp), then you would need to boost the signal with a level shifter or line amp. Option 2: Change the operating range of the BFD to +4dBu. This is a fair jump in level. The maximum input level in the -10dBV range is +2dBV (1.25vRMS), while the maximum input level in the +4dBu range is +16dBu (4.89vRMS). If the input level from the receiver supports this higher range by its ability to supply signals near maximum, then a reduction in the gain of the subwoofer amplifier brings the balance between the sub and mains output SPL levels back into check. But, if the receiver only marginally provides an output that exceeds the -10dBV levels, then the resolution and overall signal to noise level will suffer. You want to take advantage of as many bits as possible. The bit resolution defines the dynamic range of the system and so the signal to noise ratio is maximized by using as much of the dynamic range as possible. If the range from your weakest signal to the strongest signal was only half the required maximum input level, you would be robbing yourself of dynamic range and subsequently decreasing (worsening) your signal to noise level. You may in fact find this acceptable though. Anyone who uses gain in a BFD filter already accepts the results of this loss of dynamic range and S/N decrease. Filters with gain are directly subtracted from the dynamic range and S/N ratio. You can be the judge whether it affects the overall sound. Quote:
brucek | ||||
| | #19 (Link) | |||
| Re: EQ'ing my new IB My Denon AVR-1905 sub-out level is pretty high. With the Denon sub-out set to its minimum at -12 dB and the BFD input set to -10 dBV, the BFD input was clipping on reference level DTS material like "The Haunting." Setting the BFD input to +4 dBu allowed me to increase the Denon's sub-out to -2 dB. That helped the Denon's signal-to-noise ratio too. We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
| | #21 (Link) | |||
| Re: EQ'ing my new IB There is more to choosing the crossover than the LF capability of your mains. My mains have strong output below 60 Hz and I was using a 60 Hz crossover. But I determined that the in-room response of my mains had a hump between 90-130 Hz. Setting my crossover up to 80 Hz attenuated this by a few dB, and the system sounds much better. We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
| | #22 (Link) | |||
| Re: EQ'ing my new IB Sure. My Denon's noise floor is constant from the lowest volume to the highest. I was able to turn up the subwoofer pre-out level from -12 dB to -2 dB, which did not increase the noise level. I then decreased the amp's gain -10 dB. Thus I reduced the audile noise by -10 dB. (I eliminated audible noise altogether by using a BFD filter to simulate a low-pass.) We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
