| Blu-ray | DVD | Disc Media Players What receiver is best match for blu-ray player?Discuss What receiver is best match for blu-ray player? in the Home Theater | Audio and Video forum; What receiver is best match for blu-ray player? Hello HT lovers,
It has been very long times I had been played home movie theater since most of my ... |
Views: 2463 - Replies: 18
| What receiver is best match for blu-ray player? Hello HT lovers, It has been very long times I had been played home movie theater since most of my times is concentrated in DIYing and listening to my two channel system. That mean I do not know anything about HT. I need your help to build my family's HT which my wife loves to watch movies with over every weekend. I know that blue ray discs are new technology nowadays but I do not know which brand name' s model of a receiver could use with blue ray disc player. My price range is under 1K. Thanks all your help and suggestions. Best, Tan | ||||
| | #2 | |||||
| Re: What receiver is best match for blue ray player? Quote:
Theres some Onkyo's, Yamaha, Pioneer, Denon and a lot more ... ![]() Besides that feature ... What else Do you expect to get from receiver??? ... How many watts per channel??? ... How many HDMI, component, optical, etc. inputs/outputs??? ... 5.1, 6.1 or 7.1??? I read that the best bang for the buck is Onkyo 805 ... ![]() Last edited by salvasol; 08-07-08 at 04:48 PM.. Reason: links | |||||
| | #3 | ||||
| Re: What receiver is best match for blu-ray player? Ditto to everything. Also check out the new Harmon Kardons, especially if you can get them refurbed from the official reseller on ebay. You can start here for looking for any of these: http://www.hometheatershack.com/home-theater-receivers/ Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #5 | ||||
| Re: What receiver is best match for blu-ray player? Hi Tmack, I only watch HT movies with my wife and kids over the weekends but listen most of the times to two channel system (sometimes vinyl system). What kind of tube preamp and amplifier are you using? Regards, Tan | ||||
| | #7 | ||||
| Re: What receiver is best match for blu-ray player? You can very easily get into a good quality receiver for under $1000 as was already mentioned the Onkyo, Yamaha, Pioneer, and HK make some nice stuff. If you do listen to two channel music I would make sure your receiver you choose has a "Pure Direct" mode as this will bypass all the internal processing and give you supper clean nice sounding music. The Surround modes of todays BluRay movies require a newer receiver that has the capability to decode Dolby TruHD and DTS Master audio so make sure you look for that. Dont be fooled by HK's low power ratings on there receivers as they rate them differently than most others. Onkyo's TX SR805 is at this time one of the best receivers to get and can be found for around $600. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #8 | ||||
| Re: What receiver is best match for blu-ray player? The Denon 988 (2808 clone minus an option or 2) can be found for around 6 beans as well. It decodes all codecs, via HDMI. I like mine, although I've never heard the amplifier, because I bought it to use as a Pre/Pro with a outboard amp. No issues so far. "I want MY cigarettes Nurse Ratched, MINE noone elses"!! | ||||
| | #9 | ||||
| Re: What receiver is best match for blu-ray player? Onkyo is my choice. They seem to be almost unmatched in their whole receiver lineup. Providing what you need in just about any price point. | ||||
| | #10 | ||||
| Re: What receiver is best match for blu-ray player? Is there a comparison between the 805 and 806... would you recommend the 805 over the 806? | ||||
| | #11 | |||||
| Re: What receiver is best match for blu-ray player? Quote:
![]() For the price difference I doubt that its worth it. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
| | #12 | ||||
| Re: What receiver is best match for blu-ray player? Did you decided on the AVR??? ... Or you already purchased??? | ||||
| | #13 | ||||
| Re: What receiver is best match for blu-ray player? Ok, one more question. Anyone know how the new Onkyo receivers handle a 4 ohm load? I have all 4 ohm speakers using separate amps. If I go with a new receiver I may consider using the receiver amp section for home theater. | ||||
| | #14 | ||||
| Re: What receiver is best match for blu-ray player? It handles 4ohm just fine, My Mains are 4ohm and it ran just fine. (Its rated THX Ultra2 meaning that it has to drive a load of 3.2ohms) The only thing would be that it would get warmer then if using 8ohm speakers. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #15 | |||||
![]() If that's the case, I think they will perform better with the separate amps (I'm sure you're feeding them with at least 150RMS,Right???) ... most AVR are rated 100WPC and in some cases 130WPC, but I'm sure you'll get a better performance with the external amps ... | |||||
| | #16 | |||||
I was just trying to clean up and thin out my AV cabinet, getting pretty tight and warm in there ![]() Darren | |||||
| | #17 | |||||
| | #18 | ||||
| Re: What receiver is best match for blu-ray player? With the Onkyo you really only need to power the mains with an external amp and even thats not nessisary. The Onkyo has lots of power and will have no issue what so ever driving your surrounds. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #19 | ||||
| Re: What receiver is best match for blu-ray player? I have a few fans going currently... was just trying to minimize the heat if I could. I have no problem sticking with my separates, they are much higher quality... just toying around with ideas. | ||||
