Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Blu-ray | DVD | Disc Media Players
DirecTV HR20 "Copy Protected material, cannot record"
Discuss DirecTV HR20 "Copy Protected material, cannot record" in the Home Theater | Audio and Video forum; DirecTV HR20 "Copy Protected material, cannot record" I have been recording movies and shows from my HR20 DVR to my standalone DVD Recorder for 2-3 solid years ...
Views: 1259 - Replies: 6
Old 01-23-09, 11:00 AM   #1
Alias: mpw460
User: #30197
Since: Dec 2008
  mpw460 is offline
I have been recording movies and shows from my HR20 DVR to my standalone DVD Recorder for 2-3 solid years with no problems. All of a sudden, beginning last night, I can no longer do this. I get a "Copy Protected, Cannot Record" message from my DVD recorder (RCA DRC 8052NB). I get this on every DirecTV channel that I tried, HD, SD, PPV, locals as well as all recorded material on the DVR. There has been no change to my DVD recorder whatsoever so I'm assuming that DirecTV made some type of change. Any clues as to what happened and more importantly, how to correct it? Thank a lot.
Old 01-23-09, 11:49 AM   #2
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is online now
Re: DirecTV HR20 "Copy Protected material, cannot record"
I've heard of the copy protection flag being employed for single shows before, but not across a whole service. Definitely call DirectTV and get the scoop, this is significant news.
In the meantime, if you have component out's on your Direct TV and IN on your recorder, use those. They shouldn't be copy protected.
Old 01-23-09, 12:17 PM   #3
Alias: mpw460
User: #30197
Since: Dec 2008
  mpw460 is offline
Thanks for the tip. Hopefully, my DVD recorder has component-ins, I believe that it does. I thought I had read somewhere though that you can't use HMDI & component out simultaneously from the DirecTV HR20 (I currently have the HDMI out going to my projector). I could be wrong about that though...I hope! Thanks again.
Old 01-23-09, 12:55 PM   #4
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
You're welcome.
Old 01-23-09, 04:20 PM   #5
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
mpw460 wrote: View Post
Hopefully, my DVD recorder has component-ins, I believe that it does...
I found this online:
Other connections include one component video output, one S-video output and two inputs, one composite video outputs and two inputs, and one analog audio output and two inputs.
You have to use either S video or composite to record ...the componen is just output
EDIT: After re-reading your first post, you didn't mentioned how is the system connected (I'm sure you're using Svideo or composite, Right??? you don't have HDMI or component inputs on the RCA)...if that's the case, try re-setting the RCA, or connect through TV outputs.
Old 01-24-09, 08:41 PM   #6
Alias: mpw460
User: #30197
Since: Dec 2008
  mpw460 is offline
Just wanted to let you know that the solution turned out to be simply rebooting the DirecTV HR20. Thanks for the input & advice.
Old 01-24-09, 08:45 PM   #7
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
What kind of connection are you using between HR20 and RCA, composite/analog???
« Home Theater Shack > Home Theater | Audio and Video > Blu-ray | DVD | Disc Media Players »
"copy, directv, hr20, material, protected, record"
