thanks redsandvb, for those specs. information on the Oppo 203 that's a Giant step over the 103, in addition to getting rid of the Apps I love it,
I did own a 103 which I sold a few months ago my main gripe was with the Apps and the player keep freezing up at least once per month I had to call Oppo two times to get an escape plan, and as "Ron" suggested with the Apps absent in the new Gens it should really speed up things, I'm looking to visit Oppo again but I'm watching and reading a little longer:wink2:
That's the first I've ever heard of an actual owner complain of an older Oppo player. I've been following the Oppo 203 thread over at AVS and many owners are complaining that it was rushed to market too soon. My Samsung is cheap plastic but I never have had it freeze up on me. I would think they'll get the bugs worked out with firmware updates but until they do I'll be sticking with the k8500.
Yeah, I'm betting Oppo gets the bugs squashed eventually.
As for me, I don't have a UHD TV yet so don't need to pick up a 203 just yet. In fact, I just picked up a used 103D. Only problem for me is that some studios are keeping the Atmos audio for their UHD discs and leaving their standard BDs with TrueHD or DTS MA :frown:
I got the change to measure the output of OPPO UDP-203 UHD Player for digital errors.
I used my Blu-Ray (1080p) calibration disk loaded to OPPO's drive and the CalMAN's ColorChecker Classic (+Primary/Secondary Colors with 100% Saturation / 100% Stimulus Level) Chapter with DVDO AVLab TPG Color Checker function (where it displays the digital level of the selected pixel on screen) to measure it's pattern output for digital errors when you playback a blu-ray.
I measured also the same patterns from the Blu-Ray ISO of my calibration disk loaded from it's front USB and found total agreement with the measurement from the drive.
Here are the results of that test:
This player is bit-perfect @ it's YCbCr 4:4:4 / 4:2:2 output and has some errors at it's RGB-Video Output.
How would that relate/compare to say another 4K BR player? ...Like for example, a Panasonic DMP-UB900.
Fair question on the Oppo 203 vs the competition; video top quality performance wise with 4K BR, HDR10, regular 1080p BR, 3D BR, ...tra-la-la all the best moving pictures with high dynamic range and ultra high definition (natural razor sharp detailed images with real depth, and the most natural/realistic colors).
And! In real video watching tests too. Like from some of the top 4K BR disc transfers.
Quick Update to the Digital Error test I performed with OPPO UDP-203 and posted the results earlier here, I have checked the HDMI Input also for digital errors using an YCbCr 4:4:4 / 4:2:2 8bit HDMI Input signal and I found it bit-perfect also!
I looked @ the most recent Oppo 203 thread and this is it.
Release date: March 24, 2017
Category: Latest Public Beta Test Release
Main Version: UDP20X-41-0317B
Loader Version: TF0030
MCU Version: MCU203-01-1118
Release Notes:
1. Added the Dolby Digital and DTS options under the S/PDIF Output setting in Audio Output Setup, which allows the player to re-encode different audio formats into the Dolby Digital or DTS audio format for the S/PDIF output.
2. Improved the output accuracy when using the RGB PC Level color space.
3. Resolved a frame dropping issue when using cable or satellite boxes through the HDMI In.
4. Improved A/V sync when using the HDMI In.
5. Resolved an issue where the Full zoom mode would not fill the screen when playing 4:3 content.
6. Improved stability when accessing SMB servers.
7. Resolved an issue where ejecting the disc tray could lock up the player.
8. Improved compatibility with Optoma 4K projectors.
• General disc compatibility improvements based on recent and upcoming UHD Blu-ray releases as well as user-submitted disc samples.
Ron, from your Oppo 203 are you using both HDMI outputs or only the main one?
Also, how is your overall experience so far with Blu-rays from your 203's operational side?
And last, your Yamaha pre/pro; do you think it can carry Dolby Vision from its HDMI outputs?
One more ...4K is the new BR format, and slowly it's getting HDR better, and Dolby Vision is just around the corner, and Dolby Atmos is getting more and more exclusive to 4K Blu-ray discs from many studios now...the big push plus the let go of 3D immersive audio support for the immersive video BR discs...like 'Fantastic Beasts and Where to Find Them' from Warner Bros. It is alarming and disconcerting but c'est la vie; 3D good bye, and 4K we all need to buy. We have no choice, they don't make low res TVs anymore (1080p only), or quasi not. How long till you convert the rest of your home theater rig to the next higher Dolby Vision level?
Cheers,
Related Threads
742.3K posts
170.9K members
Since 2006
