Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Elite Screens offers the finest in affordable projection screens. RAM Electronics: Audio, Video, Home Theater and Computer Cables. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices ePVision.com: One-Stop place for High-end HDTV, Media hub in the box, Advanced ATSC/QAM/NTSC Tuner Receiver, Network HD Media Player and etc. Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. SVSound GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Home Theater Shack Stores Movie Stuff Vendors
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > Blu-ray | DVD | Disc Media Players
Views: 796 - Replies: 13
Old 03-06-10, 01:02 AM   #1
Bass
Since: Nov 2008
sacramento california
  bassman_soundking is offline
computer bluray player or stand alone?
So it is confirmed I am getting a bluray player for my b-day. I have to decide weather to get a comp one that will burn or a stand alone one.
Do comp ones need updates and can they do things like bd live? I have never had a bluray b4, so I dont know what options I can and cant get on a comp one as compared to a stand alone. With a computer bluray I can make a copy of movies as a back up in case kids scratch em. Anyone with any insight please share with me and tell me the advantages of each type and the disadvantages if any.
! more question, Would I even benefit fom a bluray player, I have a projector that can display 480p 720p and 1080i, and a tv that will do the same. Thanx
Old 03-06-10, 01:32 AM   #2
Jim
Wetumpka
  JimP is offline
Re: computer bluray player or stand alone?
You need to take a close look at the cost of blank bluray disc. You may find that burning them cost about as much as buying used ones that have the audio and everything done correctly.
Another concern would have to do with getting the updates to play disc that weren't correctly mastered. Can't help but think that it would be a bigger problem than dealing with mainstream players.
Then you have the question about what to do with 3D. How much do you really want to drop into a technology that's being replaced.
Old 03-06-10, 01:39 AM   #3
Bass
Since: Nov 2008
is 3d gonna replace 2d? I have programs that will copy exactly perfect (friend uses it). The computer drive seems so much simpler, smaller slot ready to drop in etc...but if a stand alone has better picture quality or better faster updates etc.... I want that. For $200 I can get 25 blanks with the player/burner
http://cgi.ebay.com/LG-Blu-ray-8X-SA...item3caaae2758
Old 03-06-10, 03:39 AM   #4
Shack Moderator
recruit's Avatar
John
Since: May 2009
UK - Near London
  recruit is online now
[mod comment] - If you are talking about copying disks it is illegal and in breach of copyright and this thread will be closed.
As for the topic if using a HTPC which can play BD I have both, but prefer to use a standalone player as the quality and ease of use is better.
Old 03-06-10, 02:06 PM   #5
Bass
Since: Nov 2008
I thought the law allowed one back-up only copy? If not then I wont do it. I may have been mis-informed. Recruit you stated the quality is better from the stand alone? That is where my main concern is. Also do you need a hdcp compliant video card to pass full resolution, and if so does my card do it? I have a Pny Nvidia Geforce 6600 256 mb pci-e. Some cards say that they are HDCP compliant and some do not. Thanx
Old 03-06-10, 05:15 PM   #6
Shack Moderator
recruit's Avatar
John
Since: May 2009
UK - Near London
bassman_soundking wrote: View Post
The term backup was not used only mentioning copying which is illegal, If you have bought a disc and back it up then that is different, obviously your post was not clear on that and wanted to make people aware of this.
Ref to your point, HDCP is required when running full resolution 1080p24 and for HDMI input most certainly even when using the adapter to convert DVI to HDMI, your card is not the most powerfull one and may struggle if trying to play BD at those resolutions, I use an ATI 4870 card and is powerful enough to do the job, I do feel though that a dedicated player is the best for enjoying BD films, something like the Sony S360 is a bargain and gives excellent results for not much outlay plus you are able to bitstream the HD audio which I cannot do with my current HTPC which converts to LPCM instead.
Old 03-06-10, 06:46 PM   #7
Bob
Since: Apr 2008
Dollars, Taxes
  240V is offline
The OP would also have to BUY software to play bluerays on the computer BD player. Power DVD or WinDVD whatever and their associated problems. I bought an open box special stand alone player and use component connections to my old 1080i CRT HDTV and 7.1 analog to the old AVR. works great. No handshake issues and I get DTS HD Master Audio and Dolby TrueHD!
Old 03-07-10, 02:01 AM   #8
Shack Moderator
recruit's Avatar
John
Since: May 2009
UK - Near London
Yes, and the software can be a bit buggy sometimes too, well I found that has been the case with both Power DVD and WinDVD
Old 03-07-10, 11:09 AM   #9
Bob
Since: Apr 2008
Dollars, Taxes
  240V is offline
My Samsung BD player gets Blockbuster and Netflix movie rentals by internet download along with Pandora radio, You Tube and newer players have more features every year! Best Home Theater improvement for reasonable investment!
Edit: Oh ya, you can get a good BD player for the cost of a proper Vcard, player software, internal BD optical drive etc and it comes with an excellent remote control.
2nd Edit: The Samsung BD-P3600 works perfect on my Acer H233H monitor thru HDMI.
Old 03-07-10, 04:41 PM   #10
Bass
Since: Nov 2008
I still need to know if comp bd players need updates like stand alone.
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater | Audio | Video > Blu-ray | DVD | Disc Media Players »
alone?, bluray, computer, player, stand
Bookmark and Share
Dish Network
Search Engine Friendly URLs by vBSEO 3.3.2
