Discuss would OPPO Blue ray play 3d blue ray in the Home Theater - Audio / Video forum. Folks
Does anyone happen to know if OPPO BluRay player will support so called 3 D bluray dvd's ? I ...
Does anyone happen to know if OPPO BluRay player will support so called 3 D bluray dvd's ? I am considering the samsung 3D LED TV and they list a BD player which is 3D capable. do I really need that kind of BD player or oppo would do the job ?
Hello,
I will also add the PS3 to the list. However, I am almost positive it will be at a reduced resolution than the newer BDP's.
Cheers,
JJ
Hello JJ, I would have mentioned the PS3 but at the moment the 3D firmware update which will be available in June will not support Blu-Ray movies that will be a separate update it will be available some this year(hopefully). I was under the impression that the OP would want this feature immediately with his new 3D TV.
The reason I talk to myself is that I'm the only one whose answers I accept.-George Carlin
Sony certainly thought ahead when designing the PS3, it just shows you how much power the PS3 has and they are to unlock such features via firmware updates, pretty impressive although I would like to see one up and running against a dedicated player !
Does anyone know if OPPO will provide 3d support via a FW update like SONY is doing for the PS3? Anyone know of any technical reason they wouldn't be able to? (Maybe the PS3 is a software vs Custom chip player).
