Sony BDP-S370
bdp-s370 sony
4K views 11 replies 4 participants last post by  benbo
#1 ·
#3 ·
I have had a Sony BDP-S370 for 3 months now and have been really pleased with it. It is very fast to load, compared to the BDP-S350 it replaced. Regarding 3D there is supposed to be a firmware upgrade that will provide this feature later. The feature I like best though is it came with iPlayer for UK use. It is also DLNA capable and I can stream mp3 and video from my NAS. All in all one of my best upgrades.
#6 ·
Why not upgrade then, you know you should.:D
It is what the game is all about. :T
By the way I like my BDP-S370 so much I am thinking of putting one in the bedroom, mainly to get iPlayer though.
#8 ·
Although the BDP-S470 is Wi-Fi capable so may be worth the extra.
I don't have a cable in to the bedroom yet so that would be a big bonus for me. I see Amazon have it for £158.07, funny price.
#9 ·
I own a pair of Sony S370s and thought that I would try a wi-fi ready player. As luck would have it I was walking thru Sams(thats what I told my wife anyway) and saw the Sony BDP-BX37, which I was told was Sams/Costcos model of the S570. I saw the BDP BX37 , which is the 370 and after discovering that wi-fi ready meant ordering Sony's proprietary wireless adapter, I cheaped out for the BDPBX37. I did not do my homework before the purchase and discovered that the adapter sells for $60 to $75 dollars.
With the BDP37 still in the box I am pondering whether to return it for the BDPBX57 which is wifi equipped, notice I did not say ready, or use the BDP37 as a player with excellent reviews.
I have also considered the entry level Oppo and forgetting about a wireless player. Suggestions?
#10 ·
If you are seriously looking at getting one of the best VFM players on the market then I would look at the BDP83 from Oppo as it just does everything right and you can add a wifi adapter later on if you want to, BD quality is top notch but it is a true universal player and DVD playback is brilliant thanks to the VRS chipset.
#12 ·
Yes, the BDP S370 requires the Sony UWA-BR100 USB wireless LAN adapter. A web search makes note that other wireless USB adapters don't work. Note that Sony commands $70 for the adapter. It is not included in the box. Moving up to the S570 in cheaper than purchasing the S370 plus the required wireless adapter.
