Hi mech, yep it is a very good BD player and for that price a bargain, I'm sure I read somewhere that it could also handle 3D BD, I have the BDP-S363 and it gives a superb picture and sound and IIRC the 370 is its replacement
I have had a Sony BDP-S370 for 3 months now and have been really pleased with it. It is very fast to load, compared to the BDP-S350 it replaced. Regarding 3D there is supposed to be a firmware upgrade that will provide this feature later. The feature I like best though is it came with iPlayer for UK use. It is also DLNA capable and I can stream mp3 and video from my NAS. All in all one of my best upgrades.
I own a pair of Sony S370s and thought that I would try a wi-fi ready player. As luck would have it I was walking thru Sams(thats what I told my wife anyway) and saw the Sony BDP-BX37, which I was told was Sams/Costcos model of the S570. I saw the BDP BX37 , which is the 370 and after discovering that wi-fi ready meant ordering Sony's proprietary wireless adapter, I cheaped out for the BDPBX37. I did not do my homework before the purchase and discovered that the adapter sells for $60 to $75 dollars.
With the BDP37 still in the box I am pondering whether to return it for the BDPBX57 which is wifi equipped, notice I did not say ready, or use the BDP37 as a player with excellent reviews.
I have also considered the entry level Oppo and forgetting about a wireless player. Suggestions?
If you are seriously looking at getting one of the best VFM players on the market then I would look at the BDP83 from Oppo as it just does everything right and you can add a wifi adapter later on if you want to, BD quality is top notch but it is a true universal player and DVD playback is brilliant thanks to the VRS chipset.
Is the wireless proprietary? If so then it should have been included in the box. I believe my Sony TV has a couple of different adapters that will work with it.
Yes, the BDP S370 requires the Sony UWA-BR100 USB wireless LAN adapter. A web search makes note that other wireless USB adapters don't work. Note that Sony commands $70 for the adapter. It is not included in the box. Moving up to the S570 in cheaper than purchasing the S370 plus the required wireless adapter.
Related Threads
742.3K posts
170.9K members
Since 2006
