| Blu-ray | DVD | Disc Media Players Firmware update now up to 4.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1Discuss Firmware update now up to 4.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 in the Home Theater | Audio and Video forum; Firmware update now up to 4.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 Here is a link to a website that has a utility that will burn the .iso file to a CD-ROM:
Views: 11514 - Replies: 58
| | #26 | ||||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 Here is a link to a website that has a utility that will burn the .iso file to a CD-ROM: http://isorecorder.alexfeinman.com/isorecorder.htm This is a .dll file that will allow you to burn the .iso file by right clicking on it. This has worked for me 3-for-3, and I burned at maximum speed. I have heard all kinds of stories about Nero, and that Roxio just won't work (verified!), but I have never heard a bad report about Alex Feinman's ISO Recorder. Just remember it's a CD, NOT A DVD! | ||||
| | #27 | ||||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 I just finished updating my HD-XA2 through the internet and the new version now is 2.5. Firmware Update Version: 2.5 Applicable Models: HD-XA2, HD-A20, HD-A2, HD-A2W, and HD-D2. Overview: As part of our commitment to provide world-class service to our customers, Toshiba is supplying this firmware update for use by purchasers of Toshiba HD DVD Player models HD-XA2 and HD-A20. This firmware update includes support for 1080p/24Hz OUTPUT, additional OSD languages, improved network connectivity supporting the download of web-enabled network content associated with certain HD DVD discs, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba. | ||||
| | #28 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-XA2 Thanks for the heads up Rodny. ![]() I updated the Original Post and just now added links to ISO firmware downloads for burning a CD to do the update for non-ethernet connected A20 & XA2 players. | ||||
| | #29 | |||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-XA2 Quote:
Don't let it happen again! ![]() ![]() ![]() ![]() | |||||
| | #30 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 I tried updating my A2 last night but it said it was up to date - although it's at version 2.2. Anyone else try updating an A2 to 2.5? Mitch | ||||
| | #31 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 With the update I get a folder (_MACOSX) with a iso file, and a file HD-A2-2501N.iso. I can double click on HD-A2-2501N.iso get CD Recorder to copy file to CD-RW. What about the folder? Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #32 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 IIRC it is something to do with burning an iso binary image on a MAC. If you have a PC you just need to have your CD-R burner software set to make a binary iso image. Using "Disk at Once" often helps. The resultant burnt disc cannot be read on a MAC or a PC. Just put in the A2, hit play, and answer yes to the update firmware request (move highlighted box to make Yes, yellow and hit OK). | ||||
| | #33 | |||||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 Quote:
| | #34 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 Hi Scott and welcome to the Shack! That's a bummer and the first I've heard of it. I wonder couldn't you update it back to version 2.2? | ||||
| | #35 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 According to the person at Toshiba that I spoke to, no, you can't go back. This is an HD-A2 btw. Just wondered if anyone else had this problem or if I should look at getting it swapped out (less than two weeks old). | ||||
| | #36 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 Updated mine with no problem. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #38 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 I have obtained a modified version of 2.5 for my HDXE-1, it has the 24fps issue fixed (it now outputs 23.9x) and it also has become region free for SD DVDs. Hopfully you guys should see the update to fix the 24fps issue very soon.Hakka. | ||||
| | #39 | ||||
| Re: Firmware update now up to 2.7 for 2nd gen HD-A2/-D2/-A20/-XA2 Updated first post in thread to reference new 2.7 firmware. | ||||
| | #40 | ||||
| Re: Firmware update now up to 2.7 for 2nd gen HD-A2/-D2/-A20/-XA2 I updated my XA2 tonight using the net. A two stage update with two seperate power-downs. Now shows version 2.7/T23T in the SETUP menu: Picture > Resolution Setting -- a choice of "up to 1080p/24Hz" (really 24/1.001 Hz) Audio > Digital Direct Audio Mode -- a On/Off choice (meant for HDMI 1.3 AVR) Now I am ready to upgrade both my display and AVR. ![]() | ||||
| | #41 | ||||
| Re: Firmware update now up to 2.7 for 2nd gen HD-A2/-D2/-A20/-XA2 Thanks Bob!! ![]() I'm downloading!! ![]() | ||||
| | #42 | ||||
| Re: Firmware update now up to 2.7 for 2nd gen HD-A2/-D2/-A20/-XA2 I updated mine late this afternoon. I want one of those Panasonic PT-AE2000U projectors so bad... ![]() | ||||
| | #43 | ||||
| Re: Firmware update now up to 2.7 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 European owners of a HD-XE1 can use the XA2 v2.7 firmware update. | ||||
| | #44 | ||||
| Re: Firmware update now up to 2.5 for 2nd gen HD-A2/-D2/-A20/-XA2 Well the 2.7 update didn't fix my problem, and Toshiba doesn't seem to want to fix it. Kinda odd that a company wouldn't want to support the people who are early adopters, since our word of mouth is what can help push these products mainstream. So for now I'm using the component cables and can't watch any store bought dvd's. | ||||
| | #45 | ||||
| Re: Firmware update now upto 2.2 for 2nd gen HD-A2/-D2/-XA2 For those trying to burn an ISO file to disc, here's the program I found and used with absolutely no problems http://isorecorder.alexfeinman.com/isorecorder.htm It worked flawlessly both times I used it. There are versions for Win XP and Vista, so choose the correct iteration. Remember that an ISO image file burned to disc is NOT viewable by a computer, but when the program says it's done; it is. There are also detailed, simple instructions on exactly how to do all this at the site above. Hope this helps... ![]() Cheers, Konky. I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns. | ||||
| | #46 | ||||
| Re: Firmware update now up to 2.8 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 Updated to firmware version 2.8 See the first post in the thread. | ||||
| | #48 | ||||
| Re: Firmware update now up to 2.8 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 I have 1.6 for the HD-A2. Just remember that you can't revert to an earlier version of firmware with the HD-A2. Last edited by gsmollin; 06-12-08 at 08:17 AM.. | ||||
| | #49 | ||||
| Re: Firmware update now up to 2.8 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 Reports are that firmware version 3.0 is now available via ethernet update. No ISO download yet. | ||||
| | #50 | ||||
| Re: Firmware update now up to 3.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 I updated my XA2 to version 3.0 via a direct ethernet connection the evening of the 18th. No problems noted by me. See the edited first post in this thread. | ||||
