Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Blu-ray | DVD | Disc Media Players
Firmware update now up to 4.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1
Discuss Firmware update now up to 4.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 in the Home Theater | Audio and Video forum; Firmware update now up to 4.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1 First post in thread updated with links to ISO downloads and has Toshiba change notice. http://tacp.toshiba.com/tacpassets-i...firmwarev3.asp...
Views: 11527 - Replies: 58
Old 06-30-08, 10:42 AM   #51
Alias: Bob
Loc: Shueyville, Iowa
User: #25
  bobgpsr is offline
Re: Firmware update now up to 3.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1
Old 07-21-08, 01:21 PM   #52
Alias: BruZZi
Loc: NEW YORK
User: #23341
Since: Jul 2008
  BruZZi is offline
I'll update to v3.0
Old 09-27-08, 01:02 PM   #53
Alias: Bob
User: #25
  bobgpsr is offline
Re: Firmware update now up to 4.0 for 2nd gen HD-A2/-D2/-A20/-XA2/-XE1
Firmware 4.0 is now available via a ISO file download and then making a CD-R firmware update disc. Reports are that it does fix the 1080p24 "jaggies" problem with the titles using the AVC (H.264) video codec (which f/w 2.8 & 3.0 still had broken).
http://tacp.toshiba.com/tacpassets-i...-XA2-4000N.zip
I had success with downloading the ISO zip file, burning a CD-R with Nero Express, and loading my XA2 flash. Afterwards the UPDATE box shows it now has 4.0/T23T firmware.
Just as a check I re-watched all of Troy HD DVD with the IME on. Smooth operation. I do only use 1080i via component. Direct ethernet update did not have 4.0 available as of last night. More later.
All of the other Toshiba HD DVD player models (A1, XA1, A2, A20, A3, A30, A35, etc.) also have f/w 4.0 updates available.
First post in this thread has other Toshiba HD DVD player model's links to firmware 4.0.
Old 09-29-08, 11:52 PM   #54
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
I wonder why these are not available using direct download using the Player its self?
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-30-08, 12:41 PM   #55
Alias: Bob
User: #25
  bobgpsr is offline
Direct ethernet connected to the internet firmware 4.0 for the XA2 is now available. Most of the other models also are now starting to have 4.0 f/w available also.
Old 10-25-08, 09:43 AM   #56
Alias: Derek
Vader's Avatar
Loc: Colorado
User: #1439
  Vader is online now
For those of us that have Onkyo HD805 players, it can be updated with the XA2 4.0 FW update. Even though there is a contractual agreement between Onkyo and Toshiba to share all FW developments for the XA2 platform, I have my doubts that Onkyo will release a 4.0 under their banner, so if the 1080p/24 AVC jaggie problem is an issue, this may be the only way to get a fix (I guess it also addresses stability issues). This just goes to further show that the HD805 is just an XA2 incognito. In any case, I am floored...
Peace... Vader
Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors!
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
The Overlook Theater - Not liable for injuries sustained while laughing.
Old 11-13-08, 08:35 PM   #57
Alias: tmack
tbase1's Avatar
Loc: medina ohio
User: #3961
Since: Nov 2006
  tbase1 is offline
upgraded my A20 and A30 with great success. My SD-DVD looks close to HD-DVD.
Old 12-15-08, 11:52 AM   #58
RLA
Alias: RLA1
Loc: SoCal
User: #30266
Since: Dec 2008
  RLA is offline
Have had my A1 in the box for a long time, I may have to take it out and play again. On second thought I just remembered the agonizing load times with that beast.
Old 02-22-09, 02:00 AM   #59
New Member
Alias: mike3775
User: #34347
Since: Feb 2009
  mike3775 is offline
Sorry for bumping an old thread, but I just found this site and thanks to this thread, I found out that my HD-A2 firmware was way out of date.
Thanks for keeping others(like myself) informed by posting these updates.
I went from Firmware 1.1 to 4.0 thanks to finding this forum and thread via google.
You guys rock
« Home Theater Shack > Home Theater | Audio and Video > Blu-ray | DVD | Disc Media Players »
