Getting back into Vinyl - Home Theater Forum and Systems - HomeTheaterShack.com
 2Likes
  • 1 Post By tcarcio
  • 1 Post By Todd Anderson
post #1 of 9 Old 01-20-16, 10:31 AM Thread Starter
mpompey's Avatar
Muad' Dib
Recently I fired up my old Technics SL-BD20 to listen to MLK's I have a Dream Speech on Monday. Afterward I plopped on Fleetwood Mac to have a listen to that. I noticed having to turn my AVR up to about -10dB to get any decent sound out of my M60s. My Onkyo has a phono stage built into it as I have my TT plugged into the inputs marked Phono. But is it any good? Is it my turntable?
I'm kinda confused as to where to start my journey with vinyl and getting reacquainted with this format. I'm not sure where to start and how to enjoy decent sound.
MP
"Fear is the mind killer..."
-- Paul Atreides
mpompey is offline
post #2 of 9 Old 01-20-16, 11:56 AM
ellisr63's Avatar
Ron
Re: Getting back into Vinyl
What cartridge are you using? It has been years, but as I recall if it is a moving coil cartridge the output is normally low, and you would use a phono preamp that is for a moving coil cartridge (unless you have a high output one).
Ron
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Oppo UDP-203
ellisr63 is offline
post #3 of 9 Old 01-20-16, 01:50 PM
tcarcio's Avatar
TC
It is normal actually. Digital formats tend to be recorded much louder than vinyl. I assume you use a MM [moving magnet] cartridge. You could try a cart with higher output. As long as you can turn your gain/volume up to a good listening volume you are fine but it will never be as loud as say your CD player.
Lumen likes this.
Onkyo TX-NR809 HT receiver
HPS-4000,SR-70, John Allen, Klipsch Heresy, Speakers for L.C.R.
QSC GX-5 power amp for L+R mains
Chase Home Theater PRO-10's for surrounds
Behringer EP 4000 pro amp for the Danley DTS-10 tapped horn sub
Oppo BDP-93 universal BD player
Toshiba HD XA2 HD dvd player
Sony VW-VPLPRO1 1080p PJ
Cinema White 1.0 gain 106" fixed frame screen
Dish network with 2 Hoppers and 1 Joey
tcarcio is offline
post #4 of 9 Old 01-20-16, 02:06 PM Thread Starter
mpompey's Avatar
Muad' Dib
Thanks for the replies. I found a copy of the original manual online and it stated it used a MM cartridge. I'll double check when I get home this evening though to make sure an aftermarket MC cartridge hasn't been installed instead.
It definitely isn't as loud as CD. I'll have to keep that in mind.
-- Paul Atreides
mpompey is offline
post #5 of 9 Old 04-22-16, 12:49 PM
mpompey wrote: View Post
MP
Does your AVR have an input labelled "phono" and are you using this input?
3dbinCanada is online now
post #6 of 9 Old 04-25-16, 08:24 AM Thread Starter
mpompey's Avatar
Muad' Dib
3dbinCanada wrote: View Post
Yes it does. I'm currently using the phono input. I've learned that vinyl doesn't have the same level as digital.
-- Paul Atreides
mpompey is offline
post #7 of 9 Old 07-15-16, 05:41 AM
drummerboy1962's Avatar
Alan
A lot of people are getting back into a vinyl. I have thought about playing my old Beatles lp's.
drummerboy1962 is offline
post #8 of 9 Old 07-15-16, 09:41 AM
HTS Administrator
News Editor
Reviewer
Todd Anderson's Avatar
Todd Anderson
It seems like the vinyl experience is largely linked to quality of equipment. I've heard vinyl sound absolutely incredible...and absolutely dreadful. Set-up is also hugely important.
Once you get it dialed in, though, vinyl has a great sound.
drummerboy1962 likes this.
Todd Anderson is offline
post #9 of 9 Old 07-18-16, 10:30 AM Thread Starter
mpompey's Avatar
Muad' Dib
Just to give a quick update on my situation:
I ended up bypassing the phono stage in the Onkro AVR with an Emotiva XPS-1
Phono Pre-Amp. And the difference was incredible! The test LPs I used sounded
great and music really opened up. The best way I can describe the difference
in sound was like going from AM radio to CD.
My guess is that with everything crammed into modern AVRs today, the phono
stage was not as good as the XPS-1 pre-amp. In addition, I built a separate
turntable shelf/cart specifically for my turntable and LPs. I was able to shorten
the length of the RCAs to the new preamp from 2m ti 1m. Probably a negligible
impact, but wanted to list it anyway.
Hopefully this helps someone else. Currently saving my pennies for Project
Carbon ES TT to replace this old Technics.
-- Paul Atreides
mpompey is offline
back , vinyl
