How to fix a Cambridge Audio Azur 640C - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 35 Old 04-09-10, 09:54 AM
New Member
tester
Re: How to fix a Cambridge Audio Azur 640C
Hi , i get now the new laser but ,,,, if the dor close and the laser gose to start position , dosnt stop it and make noises :-/what can be wrong? software? some pins?`
please help me :-(
thanx
tester is offline
post #22 of 35 Old 04-19-10, 07:59 AM
New Member
tester
ok , i got it :-) it was only a pin brocken ... see picture :
http://oliver.si/IMG_0840.JPG
tester is offline
post #23 of 35 Old 09-20-10, 03:20 PM
New Member
Hello,
is anyone able to tell me what screwdriver and of what radius have u used to unlock the top cover of Cambridge Azur 640C?
Would you help me, please?
victorec is offline
post #24 of 35 Old 12-30-10, 06:58 AM
Ile
Fixed my friends Azur by swapping new laser pickup, KSS-213C cost only 5.76 € here in Finland.
Much less than I was estimating...
Thanks for your tutorial!
Top cover screws are T6 (Torx), didn't had that small bit so I used normal 1.7 mm flat driver.
Ile is offline
post #25 of 35 Old 09-15-13, 02:25 AM
New Member
Thanks so much for the easy fix, friend. This has been bugging me for months and I finally got around to fixing it today. Your tutorial was perfect. Now every disk is reading and... good tunes again! Appreciate the help. - Goof
NOW, if I could only figure out how to get that LCD display panel to brighten up. The version 1 unit doesn't have the bright button on the remote, or anywhere else. I KNOW it can be brighter because I've seen it happen once in a while but I can't figure out what triggered it- and it doesn't stick. Let me know if you have any ideas...
Goofpod is offline
post #26 of 35 Old 09-15-13, 09:59 PM
HTS Senior Moderator
HTS Reviewer
tesseract's Avatar
2 channel view
Welcome to HTS, Goofpod! Glad you found this thread helpful, good luck with the LCD display.
"I left in love, in laughter, and in truth and wherever truth, love and laughter abide, I am there in spirit." - Bill Hicks
tesseract is offline
post #27 of 35 Old 12-23-13, 11:36 PM
New Member
Hello All,
Fantastic, resourceful and very friendly forum! Good Job!
I was searching Internet and came across to the fix for my problem (hopefully) . Azur 640c slides back and forth, as soon as I place the CD in the tray.
Does anybody have post #14 pictures?
Thank you.
Aram
hunter2 is offline
post #28 of 35 Old 03-27-14, 03:25 PM
Hi there,
New here.
Just purchased an Azur 640C V2, second hand, 75 euros (about 100 bucks if I'm correct).
When I insert a CD, it either just opens up again, or gives an error ("door").
No warranty off course...
Anybody ?
Update : when I lift the part that sits on the lens with 2 screws (sorry, noobie), the CD starts playing so I guess I've found the problem. When I close it up again, it sits too tight on the lens so it doesn't play anymore...
Anybody with the same problem? Found a way to solve this?
Thx
inztigator is offline
post #29 of 35 Old 05-31-15, 03:24 PM
New Member
Dang! I last posted on this two years ago when I thought everything was fixed by way of this great thread. It turns out the fix only worked for a short time and then the dreaded Open --> Close --> Open nonsense started happening again, first sporadically and now pretty much all the time.
BUT! I found a wacky clue that does help resolve the issue during the event. If I lift the entire front of the deck about an inch (4cm) or so and let it drop (yes, drop hard!) the "Close" display will change, load the track info and the disc is ready for the Play button. From that point on it will play the disc normally until the next disc is inserted (or the door is opened for whatever reason). Then, the lift and drop is required again to get the loaded disc to be recognized. Seems like a mechanical issue with something not working until there's a downward force applied via the drop.
Ideas anyone?????
- Goof
Goofpod is offline
post #30 of 35 Old 07-05-15, 04:27 AM
New Member
Old thread, still hoping to find an answer. Your issue problem sounds similar to my issue: "If I lift the entire front of the deck about an inch (4cm) or so and let it drop (yes, drop hard!) the "Close" display will change, load the track info and the disc is ready for the Play button. From that point on it will play the disc normally until the next disc is inserted (or the door is opened for whatever reason). Then, the lift and drop is required again to get the loaded disc to be recognized. Seems like a mechanical issue with something not working until there's a downward force applied via the drop."
Goofpod is offline
640c , audio , azur , cambridge , fix
