FS: BFD1124 ~~ $60 Shipped! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Classifieds | Shopping > Classifieds - Equalization and Calibration Equipment
Discuss FS: BFD1124 ~~ $60 Shipped! in the Classifieds | Shopping forum; FS: BFD1124 ~~ $60 Shipped! Hi there, I'm selling one of my two BFDs. The reason I had two is that I had built in ...
Old 12-23-06, 11:01 AM   #1 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Hi there,
I'm selling one of my two BFDs. The reason I had two is that I had built in subs in my mains, as well as an IB. Those mains are now gone, so I only need one BFD.
This unit does NOT have the MIDI problem. I have programmed this unit through my PC many times and have no problem with it.
This unit has a slight, slight problem -- the left 1/4" output does not work properly. It seems to be a loose connection in the jack on the BFD itself. If you leave the 1/4" cable slightly out of the jack, you can get the audio. I believe that anyone handy with electronics could easily fix this. That said, I think this is not much of an issue because 1) the left side XLR inputs and outputs work fine (that's how I was using it in my system), and 2) the right side works 100% -- both 1/4" and XLRs in/outs are fully functional on the right side. Since most of us use only one half of the BFD anyway, you can ignore the left side if you want, or you can use the XLR connection either with or without an adapter.
Aside from that little problem, this unit works fine. I will even leave my filter settings in it for your enjoyment!
Included is the original box and manual. Also, a standard PC type power code is included, but is probably not the original.
All this for only $60 shipped to your door in the lower 48. I use FedEx with insurance. No extra charge for PayPal, which is preferred!
Thanks a lot, and let me know if you have any more questions.
-- Otto
Old 12-26-06, 11:37 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
Re: FS: BFD1124 ~~ $60 Shipped!
Sold!
-- Otto
« Home Theater Shack > Classifieds | Shopping > Classifieds - Equalization and Calibration Equipment »
Mach 5 Audio
