FS: Epik Sentinel 12" Subwoofer - $475 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 1 Old 08-10-16, 03:38 PM Thread Starter
Nik
Flawless condition. Will be $$ to ship, so if interested let's talk to get some quotes. I do have the original box, but I think it'll have to be double boxed. I've had this sub for about 3 years I think. No problems with the amp!
The Epik Sentinel measures 14.5" wide x 20" tall x 20" deep and weighs almost 90 lbs. It is a slot-ported subwoofer with its 1-1/4" high x 13" wide slot-port located on the bottom front. The cabinet is made in-house by Epik using a CNC router to shape the 3/4" MDF material. The front baffle is dual-thickness at 1.5". Internal bracing is used along with a prodigious amount of Dacron filling. The cabinet is finished in a black, textured paint. There are no feet or spikes what-so-ever and no threaded inserts or other means of attaching feet or spikes. The entire cabinet appears seamless. Only a barely visible seam within the port gives any indication that the cabinet is not simply a single, large block of MDF. All of the corners and edges are rounded.
The Sentinel uses a 12" diameter aluminum driver powered by a 600 Watt amplifier.
Slot-ported high output design
12" aluminum cone driver
Exclusive 600w RMS amplifier
Custom sculpted grill with traditional black fabric
Compact CAD designed cabinet
Precision CNC machined in-house
Environmentally friendly finish
Frequency response: 18 - 200 Hz +/-3 dB anechoic
True 16 Hz or lower in-room extension
1500w short-term RMS
Weight: 95lbs. shipped
Size: 20 H x 14.5 W x 20 D (21 w/ grill)
Designed and manufactured in our own USA factory
ngiachino is offline
epik , sentinal , sub , subwoofer , xlr
You may not post new threads
