Sony RDR-GX7 DVD+RW/-RW/-R DVD Recorder - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Classifieds | Shopping > Classifieds - Video Components
Discuss Sony RDR-GX7 DVD+RW/-RW/-R DVD Recorder in the Classifieds | Shopping forum; Sony RDR-GX7 DVD+RW/-RW/-R DVD Recorder Sony RDR-GX7 component DVD recorder - remote included with batteries - also includes 7' firewire male to male, 4' video ...
Old 04-14-08, 05:10 AM   #1 (Link)
Alias: Steven
Loc: lake ozarks MO
thewire's Avatar
User: #9828
Since: Jun 2007
thewire is online now
Sony RDR-GX7 component DVD recorder - remote included with batteries - also includes 7' firewire male to male, 4' video & audio RCA, 5' camera type input to audio and video RCA output, 5' coxial cable (non screw on type) cables, and a Sony clip on mic.
Sony RDR-GX7 component DVD recorder is the world's first standalone, dual-RW (DVD-R/-RW and DVD+R/+RW) home DVD player/recorder. Its format versatility gives you nearly complete recording and viewing freedom--the flexibility to create or view optical media for or from most computer DVD recorders. Further, the machine can accommodate the recordable optical formats required by any of your friends and family, regardless of their DVD players (though some older players do not play recordable media).
The RDR-GX7's sophisticated camcorder control capabilities lets you manage a range of dubbing and editing functions when you connect a Digital Handycam or Digital8 camcorder through the i.LINK (IEEE 1394) interface. One-touch dubbing fosters easy tape-to-disc conversion, and you can delete unwanted scenes or make a compilation of your favorite scenes with flexible editing functions such as program edit and advanced program edit.
Several picture-enhancing technologies are aimed at creating high-quality recordings, especially when transferring images from video sources such as VHS or 8 mm camcorders. The unit can play back DVD-RW, DVD+RW, DVD-R, DVD+R, CD, CD-R and CD-RW discs--offering a wealth of musical enjoyment alongside its extensive video capabilities.
The playback capability of the DVD recorder is said to be comparable to the high-end DVD players in Sony's acclaimed ES line. The player/recorder delivers stunning home-theater effects through a variety of high-performance features that optimize picture quality and effectively remove noise, such as a 12-bit, 108 MHz video digital-to-analog converter with Noise Shaped Video technology, motion-adaptive field noise reduction, pre-frame noise reduction, and pre-video equalizer technologies. Variable bit-rate MPEG encoding ensures maximum efficiency and recording time (60 to 360 minutes) for all applicable DVD media.
Whether your living room is currently home to an HDTV or you're merely thinking of "someday," the RDR-GX7 stands ready to deliver the full potential of your DVDs. Progressive scanning, referred to as 480p for the number of horizontal lines that compose the video image, creates a picture using twice the scan lines of a conventional DVD picture, giving you higher resolution and sharper images while eliminating nearly all motion artifacts. Using Sony's Precision Cinema Progressive technology, the recorder also encodes your DV (digital video) input sources in pristine 480p formatting.
During playback, the RDR-GX7 also performs 3:2 pulldown. DVD mastering introduces a common distortion when adjusting 24-frames-per-second movies to 30 fps video; 3:2 pulldown digitally corrects this distortion, removing the redundant information to display a film-frame-accurate picture. Top-of-the-line component-video outputs help minimize digital and line-scan artifacts on compatible advanced televisions, while composite- and S-video outputs bring compatibility with nearly any television.
Two sets of left/right analog-audio inputs and one set of outputs channel audio to Dolby Pro Logic receivers and stereo televisions. Both Dolby Digital and DTS 5.1-channel surround-sound signals can be routed through the player's digital-audio outputs (one each of RCA coaxial and Toslink optical) for direct connection to a full-featured audio/video receiver.
Despite its advanced functionality, the RDR-GX7's intelligent onscreen graphical user interface (GUI) is entirely user-friendly, helping you create personal DVD titles with thumbnail pictures and operate the recorder through the sophisticated Remote Commander remote control. There's no need to cue or rewind tape here, so accessing precise points in your programming is nearly effortless.
From the Manufacturer
It is the component moment you have been waiting for. Sony's RDR-GX7 DVD Recorder lets you record to DVD from your television to see the difference digital technology makes. You'll experience the benefits of DVD+RW/-RW/-R DVD format recording compatibility, Precision Cinema Progressive 480P for playback, one-touch dubbing for DV/D8 sources via the i.LINK (IEEE 1394) interface, and a user-friendly graphical user interface.
The timer recording feature and adjustable recording times (60-360 minutes) enable simple TV to DVD recording. Additional features include a variable bit rate for linear and nonlinear editing, video DAC with 108 MHz processing with NSV, a 192 kHz/24-Bit digital to analog audio converter, Dolby Digital and DTS optical/coaxial digital-audio outputs, and TV Virtual Surround with four surround modes. Invite your family into the digital age with the new RDR-GX7.
•DVD+RW/-RW/-R DVD format recording compatibility
•Precision Cinema Progressive 480P for recording and playback
•One-touch dubbing for DV/D8 Via i.LINK interface
•User-friendly graphical user interface
•Timer recording feature
•Pre-frame/post frame noise reduction
•Variable bit rate for adjustable recording times (60-360 minutes)
•Linear and nonlinear editing
Asking $200.00 shipped for any location in the USA. You can also make an offer. $20.00 S&H apply to offers made for anywhere in the USA. Paypal only.
High Speed Cable/Dial Up User - Remodeling/Designing/Building
« Home Theater Shack > Classifieds | Shopping > Classifieds - Video Components »
Similar Threads
Sony's RDR-HXD870 HDD / DVD recorder gets reviewed HDBeat Home Theater, Audio and Video News 0 08-07-07 07:00 PM
Anybody using a Sony XS955 with a HD DVD player Jerm357 Video Displays and Processors 4 06-06-07 08:21 AM
DVD Recorder with Hard Drive Bob_99 Home Theater Components 2 12-18-06 03:02 PM
Sony standalone Blu-ray recorder due by year-end in Japan HDBeat Home Theater, Audio and Video News 0 09-13-06 06:43 AM
Video review of Toshiba's HD DVD recorder - RD A1 HDBeat Home Theater, Audio and Video News 0 08-22-06 11:43 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
