$99 Network DVD Playback: Klegg MediaShare MEGA - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss $99 Network DVD Playback: Klegg MediaShare MEGA in the HD World | Computers | Games | Media forum; $99 Network DVD Playback: Klegg MediaShare MEGA Klegg MediaShare Mega: At Frys (USA) regular price $189, I've seen them on sale for $129, $139, and $99! The ...
Old 04-12-08, 06:58 PM   #1 (Link)
Bronze Supporter
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
The marketing of this device is a bit off base - at Frys it was in the hard drive enclosure isle.
While it is possible to put a hard drive inside, it is not necessary to do so.
It can be used to play media files off the network.
Why would you want one?
- you have kids that scatter DVD's all over your house.
- you want a multi dvd changer with more capabilities
- you want to have one library you can watch from multiple locations.
- you want a small box you can take with you for the weekend with a bunch of movies on it.
- you want to play your MP3 music collection on your home theater
- you want to view your pictures on your tv
The klegg is pretty small, external power brick (small)
Video outputs:
DVI (can be used with HDMI with a $5 cable)
Component (3 RCA connectors)
S-Video
Composite (1 Yellow RCA Connector)
Audio Outputs:
Coax Digital (1 RCA Connector)
Optical Digital (1 toslink receptacle)
5.1 analog out (6 RCA Connectors)
USB connector:
1 B type
Network Connector:
1 Standard RJ45 receptacle
Wireless network:
Removable Antenna
Internal Hard drive connector:
SATA-Data
SATA-Power
As Stated before, you don't need to add a hard drive to use it as a network player.
As a basic workflow, here's what needs to happen to watch a DVD on the Klegg.
You'll need a computer with software that can make a backup of a DVD you own.
The backup copy needs to make its way to the Klegg
I'll categorize and say that there are 4 ways the klegg can see your backup:
1) over a wired network (this works great)
2) off the internal hard drive
3) off an external USB hard drive
4) over a wireless network (this doesn't work well, but see the wireless section below)
Wireless network:
From what I've read, the Klegg can't do a good enough job of playing video over the wireless network.
However, the wireless network is still useful - if you combine it with an internal hard drive on the klegg (just add any PC SATA Hard drive ($45-$200))
the reason for this is that you can 'push' your movies to the Klegg over wireless - it will be slow - but they can copy overnight - once they are on the klegg hard drive - you can play them locally with no trouble at all.
The wireless network is probably also sufficient if you just want to play music through the Klegg.
How the Klegg connects to a PC over the network:
For media playback, the klegg is looking for standard shared folders from windows - there's no server/streamer application - it doesn't require media player, itunes, etc. There are some restrictions on the way the sharing has to be setup, the klegg appears to need guest account access, with no password set.
Additionally, the klegg must be able to browse the network to find the server, then browse to find the shared folder on the server. What this means is, there is no way to type in a server name or a folder name.
Also there are no parental controls of any kind.
As far as file support, the klegg will read dvd's that have been copied completely to an .iso file. This is the simplest way to go albeit it takes more space than other options. You can also copy the files from a DVD to a folder and the Klegg will read those. Either way, you'll be presented with the same menu you'd get if you put the DVD into a dvd player, and will have full access to special features, directors commentaries, subtitles etc...
The Klegg will play other file types too, .avi, h.264, Mpeg1,2,4, XviD DivX. Using these file types almost always means you need to learn a little about them - there's no guarantee that what is in them is actually playable by the Klegg - the reason for this is that unlike a typical word .doc file - where the file is always structured the same way, most of the media file formats evolved as containers for other file types called 'streams' There are dozens of different stream types for both audio and video- so there are hundreds of combinations of putting them together. I have only tried a few - I found one that worked and stuck to it. I can say that xvid files, with dolby digital surround soundtracks seem to work fine, so thats what I've used.
- Jack
Old 04-12-08, 11:07 PM   #2 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Re: $99 Network DVD Playback: Klegg MediaShare MEGA
Sounds very interesting, especially for $99. Seems to be related to the Mvix devices.
http://www.kleggusa.com/product_mediashare.html
Could you shoot an interface pic or video?
Old 04-13-08, 02:11 PM   #3 (Link)
Bronze Supporter
Alias: jack
User: #2649
Since: Sep 2006
I did some googling and came up with some additional info...
I expected that this device might be marketed under different names/brands so here's what I found:
In Korea http://www.sdt.co.kr/ I think it's under the Eureka product line.
Clicking on 'english' in the above site reveals: http://www.globalzio.com/
Right on the home page was a white version of our beloved 'Klegg' device...
Part number LX351HD
I also found a canadian Zio site at http://www.ziocanada.ca/ (Part LX350HD-N in canada)
this page should be interesting to anyone thinking of the product - this one looks a little different on the front, but klegg owners will no doubt recognize the back is exactly the same as our devices...
Hope these resources help everyone out!
- Jack
- Jack
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
XA2 and Transformers audio playback problem. What is going on here? thewire High Definition | HD DVD | Blu-ray 2 04-12-08 01:43 AM
Storing DVD on network thekl0wn Computers | Games | HTPC | Digital Devices 31 11-16-07 11:11 AM
Network music player Hakka Computers | Games | HTPC | Digital Devices 9 05-16-07 09:28 AM
DVD recorders quality / DivX playback quality, any experience on that??? Blaser General Discussion 3 11-07-06 11:44 AM
Dallas' Cotton Bowl joins exclusive club with mega-HDTV scoreboard Wayde Home Theater, Audio and Video News 0 08-18-06 05:40 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
