Zone Alarm or not? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Zone Alarm or not?
Discuss Zone Alarm or not? in the HD World | Computers | Games | Media forum; Zone Alarm or not? Anyone have any thoughts or opinions on Zone Alarm vs. the stock Windows firewall? Regards, Wayne...
Old 03-31-08, 09:32 AM   #1 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Zone Alarm or not?
Old 03-31-08, 09:51 AM   #2 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Re: Zone Alarm are not?
Yup,... hardware firewall, I would not trust a software firewall as my only protection. If I had to make a choice it would definitely be a hardware firewall, plus it'll protect your entire home network. I also use the Windows firewall behind it. Sometimes people have compatibility problems using more than one firewall. Sometimes people have problems with running two virus programs too. Personally I've never had a problem.
I'm using McAfee and AVG for virus protection and my Linksys cable gateway and Windows for my hardware and software firewalls.
Mark
Old 03-31-08, 10:14 AM   #3 (Link)
Loc: Lower Alabama
Wayne... you guys have a router with a built-in firewall don't you?
I would not recommend anything else, unless you have some ultra sensitive information on your laptop that you need double protection for. As Mark says... you may not have any issues, but then you may... and no reason to unless you just absolutely need it. If you did... the Windows Firewall should be good enough for the double protection.
Old 03-31-08, 12:12 PM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: Zone Alarm or not?
We have a wireless router that's password protected. Is that the same thing?
Old 03-31-08, 12:24 PM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
The wireless router should have a firewall it can be disabled through software but it defaults to on. That should be more than enough. As I would suspect that you do have the wireless router security encryption turned on.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-31-08, 01:36 PM   #6 (Link)
Loc: Lower Alabama
What is the model and number?
You should be able to access your router settings via http://192.168.1.1
Old 03-31-08, 01:54 PM   #7 (Link)
Alias: Derek
Loc: Colorado
Vader's Avatar
User: #1439
Vader is offline
Wayne,
I would recommend using both a software and hardware firewall. Personally, I use Zone Alarm Plus, which is a stripped-down version of ZA Pro (basically, just the firewall, and none of the other resource-hogging stuff that my browser does anyway). The main advantage of using it over the Windows FW is that it will allow you to assign permissions to individual applications, and even specify if it can act as a server or not. Also, Windows only protects against incoming stuff, but ZA will alert you to programs trying to call out. I have my Windows XP Security Center completely disabled, as I use third party stuff to satisfy my rampant paranoia…
On the hardware front, it looks as if you are covered. I would recommend that you use the strongest encryption available (128 bit WEP, or Shared Key WPA - presumably you already are since you have a password), and disable transmission of your SSID. If you really want to tighten the screws, configure the MAC Address filter to only allow computers you specify to connect to your network. Good luck!
Peace... Vader
Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors!
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.
Hmmmmm.... SVS..... No Bass Left Behind....
Old 03-31-08, 04:34 PM   #8 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Vader wrote: View Post
Wayne,
Excellent points,... this is also the way I have mine set up.
Mark
Old 05-27-08, 09:31 AM   #9 (Link)
Alias: epereira
Loc: Detroit
User: #20680
Since: May 2008
epereira is offline
Zone Alarm (free version) is a great add-on to make your system more secure. I have used it together with Norton AV and the Windows Firewall and have never had any issues in XP.
Old 06-12-08, 02:16 PM   #10 (Link)
Alias: Michael
Loc: Chesapeake Virginia
User: #3685
Since: Nov 2006
buggers is online now
Do not trust MS to protect your computer. I have used Zonealarm for many years.
Old 06-12-08, 07:07 PM   #11 (Link)
New Member
Alias: Joe
Loc: NC, USA
User: #21873
Since: Jun 2008
Bronco70 is offline
I have used Zone Alarm for about 10 years. Works well, has not caused problems and is frequently updated.
Of late the spam filter can be a little strong. Just allow ZA to put all of it in a folder.
I also am a big believer in MAC address filtering. Along with the hardware firewall from the router I feel fairly safe.
I have been evaluating Network Magic recently. There is a free trial version. Lots of interesting information provided by the program. Not sure yet about it's resource requirements. May be a bit of a hog.
Joe
Old 06-13-08, 08:01 AM   #12 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Bronco70 wrote: View Post
Joe
Good first post Joe! Welcome to the Shack!
mech
Got questions? Start a thread.
Old 06-14-08, 04:18 AM   #13 (Link)
drf
Alias: drf
Loc: Somewhere else.
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
I simply don't trust wireless networks. Period. my house is completely networked with hardware firewall and server running Norton corporate. Outside of this xp/vista firewall on individual pcs is all thats needed to prevent 100% nasties getting through. I have been surfing and downloading from many questionable sites for the last 5 years with no problems yet.
Basically there is a seasaw between convience and security, but if you are willing to put up with some inconvience physically then you don't need to suffer with poor or bloated software issues.
hope this helps
Dr F
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 06-14-08, 11:35 AM   #14 (Link)
New Member
Alias: Joe
Loc: NC, USA
User: #21873
Since: Jun 2008
Bronco70 is offline
mechman wrote: View Post
Thanks,
I did not know about this forum until recently. I have a new Integra DTC-9.8 Pre-Pro. The on board Audyssey room correction program is simply amazing. One thing it lacks though is the ability to see the results graphically.
I've known about REW for a long time but never felt the need to use it. It would have been frustrating to see a room response problem and not be able to do much about it.
Times change and with Audyssey's DSP solution it is time to use REW. Looks like I can find everything related right here.
This is going to be fun.It's good to be a little geeky, OK maybe more than a little
Joe
Old 06-15-08, 09:35 PM   #15 (Link)
DRB
Alias: Ray
Loc: Vacationland, Florida
DRB's Avatar
User: #17010
Since: Feb 2008
DRB is offline
I'm also a long-time ZoneAlarm user. I do have a firewall in my router, but my laptop goes with me to the local Dunkin' Donuts, for example, and I don't trust their network.
BTW, Road Runner customers can use a security suite sourced from CA for free. It includes CA's anti-virus and security software as well as a version of ZoneAlarm.
"You can tell by the kindness of a dog how a human should be." Don Van Vliet
You can call me Denton. Or Fido.
Old 06-15-08, 11:43 PM   #16 (Link)
Alias: doubeleive
Loc: stockton, ca. 95219
User: #12968
Since: Oct 2007
doubeleive is offline
here is my best suggestion, keep anything you must have backed up on something else, memory card, cd, dvd, tape drive, dlt, external hard drive (something not connected when not in use), keep your av updated, use a password to access your router as there is now viruses/bugs that can get into the router if not passworded properly, if you have particulary sensitive information use a hardware firewall, sonicwall is good as well as many others, and cross your fingers, big brother can get in anyway (they make sure of it, so someone else probably could as well) dont do anything illegal and you should have nothing to worry about.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
Suggestions for budget 5.1 + Zone 2 w/ Speakers Otto Home Theater System Recommendations 3 01-24-07 08:08 AM
Convergence Zone Roger Home Theater, Audio and Video News 0 09-01-06 12:30 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
