Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Converting MPEG-4 files
Discuss Converting MPEG-4 files in the HD World | Computers | Games | Media forum; Converting MPEG-4 files Okay you computer guys, help me out! Is it possible to convert an MPEG-4 audio file to MP-3? If so, ...
Views: 1261 - Replies: 6
Old 07-21-06, 07:08 PM   #1
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Okay you computer guys, help me out! Is it possible to convert an MPEG-4 audio file to MP-3? If so, how? I’m not that good with computer stuff, so talk to me like I was your first-grader!
Wayne A. Pflughaupt
Old 07-21-06, 09:42 PM   #2
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
Re: Converting MPEG-4 files
In iTunes, I know you can convert between formats by going to the preferences and choosing your destination format as your import format preference. Then select the existing source file and go to one of the menus and select "Convert to ...". It'll make a copy of the file in the destination format.
I'm sure there is other software out there that will do it.
Old 07-22-06, 12:21 AM   #3
Owner
Loc: L.A. (Lower Bama)
You can use this... it's fairly reasonably priced...
http://www.surfpack.com/downloads/10...g4tompeg3.html
A free something another would obviously be better.
Old 07-22-06, 03:28 AM   #4
avnetguy
Inactive
Alias:
User: #
Posts: n/a
A quick search found this -> http://imtoo-mp3-wav-converter.mp3to....qarchive.org/
Says it converts mp4/m4a files to wav (PCM).
Steve
Old 07-23-06, 09:21 PM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Thanks guys. From what Josuah wrote, I found in iTunes where to convert imported songs to MP3. I burned the MPEG-4 song to a disc, then imported it. Conversion accomplished!
Old 07-24-06, 04:25 PM   #6
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
I think you could have skipped the disc-burning step by simply "importing" songs that are already imported. I guess I didn't make that clear in my original post.
Old 07-25-06, 02:15 PM   #7
Alias: Wayne
Loc: Katy, Texas
User: #8
Yeah, I was pretty sure it could be done without the disc burning, but I couldn’t figure it out. I found the “Import Format Preference” option in iTunes you mentioned, but couldn’t find the “Choose Destination Format.” Hey, I wasn’t kidding when I said ya gotta ‘splain it to me like you’re talking to a first-grader! I’m really slow when it comes to computers. For instance, “importing songs that are already imported" – don’t have a clue there!
Bottom line, I was able to get the song converted to an MP3, so I’m a happy camper. And I probably wouldn’t have figured it out if you hadn’t pointed me in the right direction, so thanks again!
After I finished the burning and re-importing, I noticed that right clicking on a song in the iTunes library, there’s an option that says “Convert to MP3.” Hmm... Can it be as simple as that?
Wayne A. Pflughaupt
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
