| Computers | Games | HTPC | Digital Devices DVD Editing SoftwareDiscuss DVD Editing Software in the HD World | Computers | Games | Media forum; DVD Editing Software What is the best DVD editing software? I want to be able to cut out particular scenes to clean up ... |
Views: 615 - Replies: 3
| DVD Editing Software What is the best DVD editing software? I want to be able to cut out particular scenes to clean up a movie... make it G rated, so to speak. | ||||
| | #2 | ||||
| Re: DVD Editing Software DVD shrink is fast, free, and easy for what you're trying to accomplish. Just use the splice function to cut separate titles around the offending scenes. But, I'm sure there are many others out there. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #3 | ||||
| Re: DVD Editing Software Thanks... I have downloaded and will check it out. | ||||
| | #4 | ||||
| Re: DVD Editing Software Hey Sonnie, I have downloaded movies from my camcorder to my computor using only the microsoft media player & edited them before burning to a DVD Disk. Don't know if this helps, but editing was very easy. | ||||
