| Computers | Games | HTPC | Digital Devices Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs???Discuss Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs??? in the HD World | Computers | Games | Media forum; Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs??? Hi,
I an a novice in Home Theaters but managed to built my HT system based on a PC connected ... |
Views: 556 - Replies: 4
| Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs??? Hi, I an a novice in Home Theaters but managed to built my HT system based on a PC connected to a DLP projector which will holds my complete Media Collection. Got a problem with the Audio connection: I purchased a 7:1 Soundcard which comes with 4 Standard Stereo input connectors 1. FRONT 2. SIDES 3. CENTER & SUBWOOFER 4. REAR My speakers are all bare wire. Any ideas how to connect bare wire to a standard 1/8 stereo cable? I also would need to make a connection from the right speaker to the left (same for sides&rear) ? I keep searching for plugs and bridge connectors but am hopeless at this point. What's the right way to do this? http://c1.neweggimages.com/NeweggIma...132-006-07.jpg ASUS Xonar D2 Ultra Fidelity Sound Card With Dolby/DTS Technologies | ||||
| | #2 | ||||
| Re: Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs??? Welcome to the shack! http://www.monoprice.com/products/pr...seq=1&format=2 Use something like this to the inputs on your amplifiers. | ||||
| | #3 | |||||
| Re: Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs??? Quote:
You can't connect your soundcard directly to passive speakers. There isn't the current available to drive them from a soundcard directly. There are many active home theater speaker systems with built in power amplifers that accept 3.5mm plugs and are designed specifically to be sourced from a PC soundcard. brucek | |||||
| | #4 | ||||
| Re: Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs??? What brucek said. I'm going to hazard a guess, however, that since you're using a DLP projector you may be in a room that's too large for powered computer speakers. If that's the case, you're going to need speakers powered by outboard amplifiers. There is no shortage of multi-channel amps to chose from. You can connect them to the soundcard using the adapter "y" cables that Matt mentioned.Regards, Wayne | ||||
| | #5 | ||||
| Re: Connecting Bare Speaker Wire to 7:1 Audio Card w. Stereo Plugs??? Sure, that makes sense. I thought the newer soundcards would have the amplifier built in. Now that I think about it, doesn't make a lot of sense, does it? Well; will run it through the amplifier which is then going to be easy. I was hoping to bypass the thing since it adds so much complexity and options I would not need. Thanks, Guys. | ||||
