Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
H. T. PC
Discuss H. T. PC in the HD World | Computers | Games | Media forum; H. T. PC Hi there I'm looking at building a pc to run to my 42"LCD tv. I want HDMI connection on the ...
Views: 602 - Replies: 8
Old 08-02-08, 11:59 AM   #1
New Member
Alias: John
Gadgets's Avatar
Loc: Grand Bend On.Ca.
User: #23835
Since: Aug 2008
  Gadgets is offline
H. T. PC
Hi there I'm looking at building a pc to run to my 42"LCD tv. I want HDMI connection on the video card. I'm going to use this to stream from my home to my condo through my Slingbox.
I'm looking for some recommendations as to video cards processor (core 2 quad) motherboard. I also would like to use a shuttle style case.
Any help would be great
Old 08-02-08, 12:40 PM   #2
Alias: Bob
Loc: Shueyville, Iowa
User: #25
  bobgpsr is offline
Re: H. T. PC
Get a motherboard that has the brand new Intel G45 support chip which does proper 7.1 bitstream audio over HDMI. You will be glad you did and no need for any other video card. The G45 does hardware acceleration for the H.264 AVC and the VC-1 video codecs. Newegg has a Gigabyte motherboard with the G45.
Old 08-02-08, 01:17 PM   #3
New Member
Alias: John
Gadgets's Avatar
User: #23835
Since: Aug 2008
  Gadgets is offline
Re: H. T. PC
Thanks i will look this up
Old 08-02-08, 07:28 PM   #4
Bronze Supporter
Alias: jack
basementjack's Avatar
Loc: Chicago Suburbs, IL USA
User: #2649
Since: Sep 2006
  basementjack is offline
Re: H. T. PC
If you don't end up going the integrated route, I think there are several cards from ATI (or other vendors with the ATI chipset) that support audio over HDMI.
I recently picked up an Asus 4850 graphics card, and I really like what Asus has done with the extra utility software -you can set the fan speed on the graphics card. (windows exp index=5.9)
Another option for a separate card might be an ATI 3450 based card - I have one of these in my server - no fans at all. I believe I read that it too supports audio over hdmi. (windows exp index = 4)
- but on that note, I would still go with a G45 based motherboard as a baseline - start there and see if you need more. If you get one, and if you put vista on it, can you post back what the video score is in the windows vista exp? it'd be great to know for others here!
- Jack
Old 08-03-08, 01:37 PM   #5
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Re: H. T. PC
Also, if you go dedicated video, don't be afraid to get a card with totally silent, passive cooling. But, unless you are planning on playing video games, integrated is the way to go.
Old 09-22-08, 02:46 AM   #6
Alias: biz
Aminbiz's Avatar
Loc: California
User: #26115
Since: Sep 2008
  Aminbiz is offline
Re: H. T. PC
When building your master server always go with a stand alone video card do not go with the intergated mobo. with the demands of todays video, HiDef / Blu-ray ...etc they need to have there own dedicated video card plus with a stand alone card upgrading is no problem.When building a client server a intergrated motherboard is ok.
Old 12-20-08, 09:39 PM   #7
New Member
Alias: John
Gadgets's Avatar
User: #23835
Since: Aug 2008
  Gadgets is offline
Re: H. T. PC
I'm finally getting around to building this HTPC I have been doing some research into Shuttle SG33G5M PC. This has ir interface and it looks to support H264.
Any comments would be great
thanks
Old 12-20-08, 10:17 PM   #8
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: H. T. PC
Looks nice!
http://image.shuttle.com/ResourceCen...product_id=784
We're all in this together!
Members DIY Subwoofer Database
Old 12-20-08, 10:33 PM   #9
Alias: biz
Aminbiz's Avatar
Loc: California
User: #26115
Since: Sep 2008
  Aminbiz is offline
Re: H. T. PC
looks like a nice little box,but take a look at the storage specs(internal storage bays = 1) that is the key.
-Specifications
Chassis
G5M-type aluminum chassis (black)
Mirror front face with golden finish
Integrated VFD Media Display (Versatile front-panel display)
Storage bays: 1 x 5.25", 2 x 3.5" (1 internal) ************
Dimensions: 31 x 20 x 18.5 cm (LWH),
Weight: 3.3 kg net / 4.6 kg gross
http://www.tigerdirect.com/applicati...H4CjCmmVCjCmmV
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
