Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
HTPC display issues - help?
Discuss HTPC display issues - help? in the HD World | Computers | Games | Media forum; HTPC display issues - help? I'm having problems with my HTPC. When I turn it on, it works fine. If I change the input on ...
Views: 388 - Replies: 1
Old 10-04-08, 12:25 AM   #1
Alias: Kyle
Loc: Canada
User: #25407
Since: Sep 2008
  krips is offline
I'm having problems with my HTPC. When I turn it on, it works fine. If I change the input on my receiver to something else, then go back, it takes a long time for the computer screen to display again, even though I can get audio output. Sometimes it restarts, and sometimes it displays after say 5-10 minutes. Sometimes nothing happens and I have to restart. My receiver is a Pioneer 1017 and the computer is connected via a DVI-HDMI cable. My TV is a Sharp Aquos 42D64U I believe. Any ideas would be appreciated. Thank.
Old 10-04-08, 03:48 AM   #2
Alias: biz
Aminbiz's Avatar
Loc: California
User: #26115
Since: Sep 2008
  Aminbiz is offline
Re: HTPC display issues - help?
sounds like a handshaking issue , I have a simular situation with my HTPC when hooked up via HDMI into the receiver then into the display it takes about 20 seconds for the image to be displayed upon start-up. If you bypass the receiver using it only for the audio and plug the DVI/HDMI directly into your Sharp Aquos it should correct your problem.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
display, help?, htpc, issues
