Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Router recommendation
Discuss Router recommendation in the HD World | Computers | Games | Media forum; Router recommendation Just wondering if anyone has a recommendation for a wireless router? The one that came with my internet is the ...
Views: 368 - Replies: 7
Old 12-31-08, 08:50 AM   #1
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Just wondering if anyone has a recommendation for a wireless router? The one that came with my internet is the weak link (and out of warranty), so I'm looking for a replacement.
I've read about the new Draft N stuff and that is not necessary, but I would like 4 gigabit ports, which would pretty much limit me to the new N routers.
I would also like multiple antennas, as it has to be in the basement and third floor reception is okay, but can be spotty.
I want to move up to WPA2. I've been using WEP and have not been happy about it for years.
So far I've looked at the D-Link D-4500 and D-655. But always welcome another suggestion. I would like to stay below $100 if possible.
Thanks,
Anthony
Old 12-31-08, 01:29 PM   #2
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Re: Router recommendation
My preference has been Linksys for my cable gateway/wireless router with four ports. Has performed flawlessly, so much so that I have not thought about looking into any of the newer ones, pretty well forgot it was even there . Sorry that's not much help,... I also have a Linksys KVM that has performed perfectly.
Mark
Old 12-31-08, 01:45 PM   #3
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
What Mark said. I've had no problems with Linksys after 2 bad D-Link's.
We're all in this together!
Members DIY Subwoofer Database
Old 12-31-08, 02:48 PM   #4
Alias: Kalani
Loc: Studio City, CA, USA
User: #30435
Since: Dec 2008
  KalaniP is offline
Ditto for Linksys. I know people that swear by the DLink gaming routers, but I've had nothing but miserable experiences with DLink. (I've never played with the gaming routers, though)
And I know you think you don't want 802.11n, but it won't be long before it'll replace 802.11g just like g replaced 802.11b, and then you'll be kicking yourself for having a router that won't work for you, all in the name of saving $20.
Old 12-31-08, 10:53 PM   #5
Owner
Loc: L.A. (Lower Bama)
Linksys user here for several years at home and at the office... no issues... all good.
Old 06-22-09, 10:59 PM   #6
Alias: Erle
epereira's Avatar
Loc: Detroit
User: #20680
Since: May 2008
  epereira is offline
I have tried Dlink and Netgear and have been disappointed and so went back to Linksys. I now use a Linksys Simultaneous Dual-N Band Wireless Router (WRT610N) which has:
* Two bands of Wireless-N for high-performance wireless entertainment.
* Media Optimized Networking technology ensures smoother streaming of high-definition video, music or gaming.
* Storage Link provides USB connectivity for hard drives and portable memory.
It has been great and I have not had ANY problems whatsoever!
Erle
Old 06-22-09, 11:05 PM   #7
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Thanks for the update. An update of my own: I ended up going with a D-Link 655 Wireless N router.
There were some growing pains, and it has the dreaded overheat reboot problem when it's being really taxed, but with some mods, I fixed it:
Updated firmware
Enabled G mode only (all my clients are 802.11g)
Dialed down the power to low mode (small townhouse, no need to blare it across the street )
I usually get sustained throughput of 20 down and 5 up on my Fios, and I get 800mbps Cat 6 to Cat 6. No dropouts streaming Netflix, Hulu, or Xbox live -- and I run streaming audio and video to a Squeezebox and Xbox from a small home media server.
Overall, I'm happy with my purchase -- soooo much better than the Actiontec that came with Fios.
Old 08-04-09, 04:28 AM   #8
Alias: Guns
User: #40222
Since: Aug 2009
  8086 is offline
I second the notion for Linksys. I have used many D-Link products and the only one that's been decent and stable is my DGL-4300 (never had a reboot), however it does have UPnP/NAT problems. I recently bought my brother a Linksys WRT160NL and it's running stable, super fast, and feature packed. Plus the WRT160NL runs on linux and that means there are plenty of alternative firmware options out there like Tomato and DDWRT that provide features found in $1000+ enterprise routers for your bargain basement $100 router.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
recommendation, router
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
