Anyone ever used a USB expansion device - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss Anyone ever used a USB expansion device in the HD World | Computers | Games | Media forum; Anyone ever used a USB expansion device My piece of junk computer is out of USB ports (only had two to begin with). Has anyone ever used ...
Old 09-03-06, 09:38 AM   #1 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
My piece of junk computer is out of USB ports (only had two to begin with). Has anyone ever used an outboard USB expansion module? I’m wondering how well they work, and if someone can recommend a good one.
Old 09-03-06, 12:56 PM   #2 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: Anyone ever used a USB expansion device
I have two.
My laptop has only two USB ports and doesn't get supplied a lot of power -- something I learned when I hooked up my Rio MP3 player to it (it didn't work with the low power). I went to my local Fry's/Best Buy and bought the cheapest powered 4 port USB expander. Works totally fine as far as I can tell.
I also have one at my office. Since the computer is in an inconvenient place to access the USB ports located in the back, I bought a cord so I could plug devices on my desk. Again, bought the cheapest I could find (non-powered this time) and it works totally fine.
Maybe someone with more info could tell you why to buy a more expensive connector, but I can't think of one. The only things I'd be looking for would be powered vs. non-powered and if it's USB 2.0 compliant. Depending on how old your computer is, you may have only 1.1, so a 2.0 compliant device might not be needed. Of course, I'd probably buy a 2.0 anyway as I don't think there is much of a price difference and the 2.0 is backward compatable.
JCD
Old 09-03-06, 08:48 PM   #3 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Thanks Jacen. So if I understand, as long as the stuff I have USB’d is working fine, I don’t need a powered one? I’m going to be getting an iPod soon, so maybe I should be safe and get a powered one...?
Old 09-03-06, 09:04 PM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
How ‘bout something like this?
http://cpustuff.com/estore/product.php?productid=255
The price is so low it’s scary... I was seeing non-powered ones in the $20 range. Judging from I see here, the outboard power is for external devices that might need extra power. Since I'm gettin an iPod, maybe I should get one.
Old 09-05-06, 06:39 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Picked up a powered Dynex expander at Best Buy this weekend for about $30-35. Probably more than I needed to pay, since I’m not sure if I really needed a powered one, but though it’d be better to be safe than to have to go back later for another one once I get the iPod.
I like the layout of this one – has two ports on the back, along with the power and computer connections, and two ports on top. That way I can set it at the front edge of my desk (i.e, where it’s against the wall) and the “plugged in all the time” cabling drops off to the floor, out of sight. Meanwhile, the top connections make for easy access for my digital camera – or the iPod when it comes. If all the connections were on the front, like most of the expanders I saw, I’d have cables all over the top of my desk.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
Information and or help required. Fincave Home Theater Components 31 09-06-07 01:44 PM
Mach 5 Audio
