| Computers | Games | HTPC | Digital Devices Resurrecting a UPS?Discuss Resurrecting a UPS? in the HD World | Computers | Games | Media forum; Resurrecting a UPS? Several months ago I acquired an APC UPS that hasn’t been used in some time, so naturally the batteries are ... |
| | #2 (Link) | |||
| Re: Resurrecting a UPS? All the APC ups's I have come across have user reaplceable batteries, do you have the model number for the ups, normally on a plate at the rear of the unit. MOstly they will be sealed 12v units similar to alarm panels. | |||
| | #3 (Link) | |||
| | Re: Resurrecting a UPS? I think these are generally gel cel batteries. As Steve suggest though... model number should get you enough for a re-order. I would check with battery stores on the net... or maybe type in the model number on www.froogle.com since the replacements straight from APC are probably expensive. | |||
| | #4 (Link) | |||
| Re: Resurrecting a UPS? Try www.batterywholesale.com or similar companies like Apex. You can find them with a google search for ups batteries. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
