How do you organize the displays for your HT and how well does it work? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss How do you organize the displays for your HT and how well does it work? in the HD World | Computers | Games | Media forum; How do you organize the displays for your HT and how well does it work? This is a critical arrangement for a HTPC. I use a 1280X1024 LCD display for normal computing, and control of ...
Old 05-04-06, 10:05 PM   #1 (Link)
Alias: gs
User: #159
gsmollin is offline
This is a critical arrangement for a HTPC. I use a 1280X1024 LCD display for normal computing, and control of the PC. The second display on the graphics card is connected to my 1280 X 720 LCD pj, which is across the room. The cable goes above the ceiling. (The sound card SPDIF goes around the room).
The graphics card is a ATI 9500 pro/9700. The second display control is buggy on this card. I follow a strict sequence each time I use the pj, and the display doesn't lock up. I extend the desktop to the pj, then make the pj my pri,ary monitor, then deactivate the monitor. Going back is the reverse. Using both displays concurrently will work for only a short time, then it crashes.
Of course the 9500pro is obsolete. I should replace it. Tell me what you are all doing for dual-monitor control on your HTPC, and maybe I'll get a good recommendation.
Old 05-06-06, 12:52 PM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
Re: How do you organize the displays for your HT and how well does it work?
I use a nVidia (evga) 6600GT with 84.43 drivers. No problems driving a 15" LCD (primary) and a secondary 37" LCD (via VGA or DVI).
My other PC uses a fanless ATI 9600XT driving a 19" LCD (primary) and a direct view 34" CRT HDTV (secondary) using the special ATI VGA to component adapter. 1080i mode.
In both cases I use the "Dualview"/"extend desktop" mode -- not "clone".
Bob
Old 05-08-06, 08:04 PM   #3 (Link)
Alias: gs
User: #159
gsmollin is offline
Are those AGP cards, or PCIE?
Old 05-11-06, 11:42 AM   #4 (Link)
Tech'y Shackster
Alias: Bob
User: #25
AGP
Edit: I had to edit my post above to say 9600XT not 9800XT. Sorry!
Bob
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Mach 5 Audio
