| Computers | Games | HTPC | Digital Devices Amplifying Computer line-outDiscuss Amplifying Computer line-out in the HD World | Computers | Games | Media forum; Amplifying Computer line-out What do you recommend to amplify a HTPC line-out to a distributed audio system? I would like to boost the ... |
Views: 232 - Replies: 8
| | #2 | ||||
| Re: Amplifying Computer line-out If you're volume is up in the OS, and you're running the line out to powered AVR, you shouldn't need anything else. What's your setup, AVR, Separates, or Powered speakers? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #3 | ||||
| Re: Amplifying Computer line-out It runs out from the HTPC to a Russound CAA66 distribution amp to 6 zones. The main zone in the family room has 4 ceiling speakers. I would like more volume. The issue may be with the distribution amp. | ||||
| | #4 | ||||
| Re: Amplifying Computer line-out Yeah, you could check that by inserting a different amp into one pair of speakers and see if your volume increases. Also make sure that your in-ceiling speakers are wired to give you proper impedance. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #6 | ||||
| Re: Amplifying Computer line-out Parts express has inexpensive distribution amps rated for more power, or you could wire the 4 speakers together in a way that give you 6-8 ohms (google "series parallel speaker wiring impedence), and use a pro-amp like the Behringer A500 for more power than you'd ever need. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #8 | ||||
| Re: Amplifying Computer line-out Sure thing, let us know what you go with. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #9 | ||||
| Re: Amplifying Computer line-out What is the front end on the HTPC? Sometimes I use FFDSHOW to normalize. | ||||
| Bookmarks |
| Tags |
| computer amplification, htpc line out |
| Thread Tools | |
